Page 6 of 6 FirstFirst 1 2 3 4 5 6
Results 51 to 52 of 52
Thread: wheel alignment setups
  1. #51
    Veteran Konakid's Avatar
    Henry
    Eastern
    Any time you change any suspension compenent in the front you need an alingment as you put it out when you take bits in and out! You could drop the toe down to 1mm out total to save the tyres a bit if you are driving it daily and run more castor to compensate. With new bushes and factory castor rods you can get about 3.5 which is good because more positive castor give you camber as you turn in so you dont have to run as much static -ve camber. If you tell the aligner to max the postive castor they wil do it for you. Alignment is the best, makes everything feel more predictiable!
  2. #52
    Senior Member Deeken's Avatar
    Jan 2011
    Deeken
    Port Macquarie
    Cheers kona, that was one of the reasons I got the castor only evened up, they were like did you want the castor on max +ve or -ve, or just even it up, I was like errrr (COULDN'T REMEMBER LOL) just even it up, it'll do. rofl.
  1. wheel alignment
    By pogi in forum Technical - Questions
    Last Post: 20th September 2009, 02:19 AM
  2. Wheel Alignment Place
    By tauhu86 in forum Perth & WA Events and Discussion
    Last Post: 17th July 2009, 04:58 PM
  3. Cheapest wheel alignment
    By doridori in forum Melbourne & Vic Events and Discussion
    Last Post: 15th May 2009, 09:03 PM
  4. wheel alignment
    By 70wagon in forum Technical - Questions
    Last Post: 4th March 2009, 01:13 AM
  5. wheel alignment question
    By Akury in forum Technical - Questions
    Last Post: 13th April 2007, 09:53 AM
