Results 1 to 10 of 15
Thread: ae86 single piece tailshaft
    Default ae86 single piece tailshaft
    Heyas,
    I was thinking about getting a single piece tail shaft custom made for my ae86 (T50 -> T series diff).
    Anyone who's done this before got any advice about:
    - advantages/disadvantages of single vs 2 piece
    - who in Perth should I get to do this (I've heard Veem or Truckline)
    - exact length or any other specs I might need
    Daniel
    Jonathan
    I don't know the advantage of going to a 1 piece, except it maybe slightly lighter. But you have to use a tailshaft loop for competition anyhow. No point realy. 2 piece is designed as a better system, due to less vibration, and it fits your vehicle. 1 piece is for custom setups.
    Mt Macedon
    I tend to agree with Jonny. A single piece tailshaft will work, but will be money wasted in a standard setup.
  • #4
    Fair enough.
    My centre bearing is on it's way out atm, so I'm weighing up my options. I just don't want to waste my money on a 2nd hand replacement 2 piece if it's worth going for a single piece upgrade.
  • #5
    Senior Member lo_rolla's Avatar
    Damien
    Brissie
    Would you perhaps use a 1 piece tail shaft in a rather serious build? Still T-50 to what ever diff Mr Japanese Man out it?
    I've heard of some one gaining 15-20Hp at the wheels going to a single peice.
  • #6
    Mt Macedon
    ^^ I've also heard of someone speaking out of their arse.
    If a two piece tailshaft really wasted 15-20hp in any situation it would melt the unis/bearing in a few seconds.
    I'd only go a one piece if you needed a custom tailshaft in the first place. Not if Mr Toyota has already built a 2 piece that suits.
  • #7
    Damien
    Brissie
    Sweet as man.,
    I've already bought my new one so it doesn't matter any way.
  • #8
    jed
    n.s.w
    merimbula
    i wouldnt mind knowing how much shorter a jdm tail shaft is compared to an adm one.
  • #9
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    I replaced my 2 peice tail shaft because it was cheaper to get a 1 peice made then it was to replace the center bearing, Car feels abit more ridged now aswell.
  • #10
    Jonathan
    You can buy the centre bearing new from a few places. Shop around for prices.
    To me, the 2 piece setup seams like it would be very safe. And the idea of it is to reduce vibration.
    With a 1 piece, especialy a custom one, it is something that can go very wrong. If your diff is at the wrong angle, the uni joints will get chopped out in a short time. And if they have any movement at all, you will know about it at 120km/h. If the front uni breaks, it can pole valt the car.
    But... on GranTurismo 4 (an authority because they now design real cars), you can upgrade your Levin tailshaft for a carbon fibre 1 piece.
  • Page 1 of 2 1 2 LastLast
    1. WTB Bris AE86 Tailshaft front piece only
      By jackthecat in forum Cars or Parts Wanted
      Last Post: 7th August 2012, 11:48 PM
    2. One piece tailshaft vibration
      By Tom86 in forum Technical - Questions
      Last Post: 25th June 2010, 01:06 PM
    3. ae71 tailshaft 1 piece $50 good for 4age conversion
      By tuff te-72 in forum Car Parts For Sale
      Last Post: 19th February 2010, 09:49 AM
    4. 1 piece tailshaft length
      By KE70briskev in forum Technical - Questions
      Last Post: 31st July 2007, 12:58 AM
