Results 1 to 3 of 3
Thread: removing the inner tierod
    Glenn ke_70's Avatar
    Clay
    Barossa!
    Default removing the inner tierod
    how do u remove the inner tierod 2 install the ajps lock spacer?
    and gettin the boot off any tricks on that?
    a picture of an installed lock spacer wot in mostly after
    It's pretty much straight forward. Look at it and tackle it as you see it. Some may say to remove the tie rod from the rack end (Rack end is what you are talking about "inner tie rod") but you can leave the tie rod connected, although it canmake rethreading the rack end back INTO the rack a little difficult.
    So first. Remove the Rack boot on the rack side, pull it back.
    You will see a washer between the RACK and the RACK END. The washer should have been smacked to make it a locking tab against the RACK END.
    Use a screw driver and hammer to knock this back out so you can get a spanner on the rack end to undo it.
    Clean inside the rack thread and the thread on the RACK END. Apply lock tight to the RACK END thread and slip over the spacer.
    Thread the RACK END into the RACK thread with spacer between.
    Should be it.
    Clay
    Barossa!
    awesome 2 easy
    thanks mate
  • Similar Threads
    1. rack/tierod ends for longer LCA's
      By --Redwork-- in forum Technical - Questions
      Last Post: 16th December 2009, 11:30 PM
    2. removing 4a-c
      By Tim.duncan in forum Technical - Questions
      Last Post: 7th July 2009, 02:15 PM
    3. removing old bushes
      By loc33e in forum Technical - Questions
      Last Post: 7th February 2008, 06:45 AM
    4. tierod end connector things.
      By HiLtOn in forum Cars or Parts Wanted
      Last Post: 10th August 2007, 12:00 AM
    5. ra40 tierod ends
      By slydar in forum Technical - Questions
      Last Post: 25th April 2006, 01:00 PM
