Results 1 to 7 of 7
Thread: microtech question!! need help
    Nic
    Mt Evelyn
    Default microtech question!! need help
    hey guys i wanna know if i buy a second hand microtech tuned for a ST 20v using 4x coilpacks. will this work on my 4agte smallport??
    nic
    Dave
    define "work"
    it will definately work as a paper weight on your small port
    Nic
    Mt Evelyn
    i dont want to have to get it re programmed by microtech. i want to wire it up and get it tuned. is this possible?
  • #4
    Jonathan
    I think it probably could work. I think the dizzy pickup is similar enough, if you change the plugs and get the wires in the right order. Not 100% sure. It would be easier to use the same coils and igniters the 20v had. But may also be very easy to go back to single coil.
  • #5
    Ryan
    Quote Originally Posted by Nic19 View Post
    nope.. you'd have to send it back.. the base map with be all wrong.. like 4 values wrong..
    but the upside is that if you buy it setup for 4 coilpacks.. then its bound to come with a xbox ignitor unit also i would assume.
  • #6
    Nic
    Mt Evelyn
    yeh but buying a new lt10s comes in a package with coilpacks and x4 ignitor. just wanted to buy this if it was going to work with out being re programmed for the smallport. but obviously its not going to work.
  • #7
    Nick
    CBD
    The only thing you can't change is the ignition input on a microtech.
    Everything else can be changed with a handset or laptop. Ive been using Rotary Microtech's for years on toyota's. Im even using a microtech programed for a 13bt on my VN v6 (As a piggy back for the Boost ).
    Any "Good" Tuner will be able to change the injector timmings.
    The 20V uses a 24 toothed speed wheel and 1 home position in the dizzy with a microtech.
    If your dizzy has both of those then you will be able to use it.
    But i always recommend buying new, Its alot safer and in the end maybe cheaper in the long run.
  • Similar Threads
    1. TVIS question.... Do I need it? 4age with Microtech
      By maxhag in forum Technical - Questions
      Last Post: 28th August 2011, 11:49 AM
    2. microtech ecu Lt10s question
      By sdrawkcab in forum Technical - Questions
      Last Post: 19th January 2010, 07:33 PM
    3. Quick clutch question and spigot question
      By wideslider in forum Technical - Questions
      Last Post: 9th August 2008, 12:45 AM
    4. microtech
      By wide body86 in forum Technical - Questions
      Last Post: 5th July 2008, 07:30 PM
    5. Microtech HELP
      By johnO2 in forum Technical - Questions
      Last Post: 20th April 2007, 09:30 PM
