Results 1 to 4 of 4
Thread: where is the vacuum advance on a Aisin carby?
    Default where is the vacuum advance on a Aisin carby?
    hey guys, I drive a stock AE82, be nice
    I removed the stupid vacuum rail thingie, but now i can't find which vacuum line is the vacuum advance.
    anybody know which one it is? Also, my dizzy has 2 vacuum thingos, is one for high revs and the other for really low revs?
    Thanks
    Aaron
    vacuum advance is only on the dizzy. and any vacuum to the dizzy will do.
    ic, so why has the dizzy got 2 vacuum lines connected to it?
  • #4
    Jonathan
    They system is far more complex than just 2 vacuum lines. But, if you want to throw most of the vacuum lines away and block off the holes, you can. Then you need just 1 hose from the base of the carby somewhere, to the advance diaphragm of the dizzy. (Some dizzys have 2 diaphragms, one advance, the other retard).
    So you want to know which hole on the carby to use? Put your finger over the holes and see which one gives good vacuum with part throttle as you rev the motor. The other port is for the charcole canister.
  • Similar Threads
    1. Heads up: Cheap re001 at Advance Tyres Richmond
      By geoff in forum Melbourne & Vic Events and Discussion
      Last Post: 31st October 2010, 11:30 AM
    2. brand new aisin ae86 clutch master cylinder
      By jezza11 in forum Car Parts For Sale
      Last Post: 9th June 2010, 11:44 AM
    3. other options for vacuum...
      By fantapants in forum Technical - Questions
      Last Post: 28th May 2009, 06:37 PM
    4. 4ac carby vacuum lines
      By skit in forum Technical - Questions
      Last Post: 17th April 2008, 09:16 AM
    5. Advance timing
      By 4age '71 in forum Technical - Questions
      Last Post: 23rd November 2007, 08:45 PM
