Results 1 to 9 of 9
Thread: shortend tail shaft
    jed
    n.s.w
    merimbula
    Default shortend tail shaft
    hay fellas im thinking of getting an adm tail shaft shortend to allow for a t series diff.
    just wondering how much shorter the jdm shafts are compared to the adm shafts.
    cheers guys jed
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    wut?
    they are the same length?
    are we talking apples and apples or oranges and apples?
    do you want to know different length of an 'S' series tail shaft is compared to a 'T' series tail shaft?
    or if adm 'T' series is the same length as jdm 'T' series?
    FTP.
    jed
    n.s.w
    merimbula
    sorry more like pears and bananas
    yer sorry guys whats the difference in length between the s series shaft and the t series shaft.
    thanks jed
  • #4
    Jonathan
    Clinton: you have no idea. Let's just leave it at that.
    jed: the difference is about 20mm, as I had them side-by-side a few days ago. But I didn't measure. I could measure if I realy had to.
  • #5
    jed
    n.s.w
    merimbula
    that would be grate if you could, only because i wanna ring the diff joint to find out how much it will be to shorten the adm one.
    cheers mate jed.
  • #6
    jed
    n.s.w
    merimbula
    i take it that only the rear of the shaft has to be shortend. correct me if im wrong
  • #7
    Clinton
    Tweed Heads
    Quote Originally Posted by Jonny Rochester View Post
    coz i didnt get the post?
    right on!
    OP: go to a wrecker and get an RA40 tailshaft. you might be able to get away with using the back half of the tail shaft straight onto the s series.
    if not. at least youll have the stuff for a shaft place to make it. it would be cheaper aswell i think
    FTP.
  • #8
    jed
    n.s.w
    merimbula
    well ive alredy got an adm shaft for an s series diff but am putting a t series diff in and need it to be shorter. all i really need two know is how much shorter a jdm shaft is, so i can either get mine shortened or get a rear half of a jdm or t-18 shaft depending on how much it costs to shorten it.
    cheers jed
  • #9
    Over here in WA, if you were to go and have it shortened by a diff / tailshaft specialist it would probably end up being just as much or if not more than finding a t18 peice.
  • Similar Threads
    1. tail shaft
      By 4ag te72 in forum Cars or Parts Wanted
      Last Post: 10th November 2012, 11:59 AM
    2. Tail Shaft
      By Drew in forum Car Parts For Sale
      Last Post: 28th October 2009, 10:35 PM
    3. W.T.B tail shaft
      By ae71dwrifda in forum Cars or Parts Wanted
      Last Post: 12th May 2009, 07:58 AM
    4. T18 re tail shaft or JDM tail shaft & Rear JDM brake hose
      By jy086 in forum Cars or Parts Wanted
      Last Post: 5th May 2009, 10:45 AM
    5. tail shaft
      By AE71briskev in forum Cars or Parts Wanted
      Last Post: 23rd February 2009, 08:09 PM
