Results 1 to 9 of 9
Thread: panhard rod is seized up to the max
    Jun 2005
    ok, my panhard rod has seized up to the max. when i first put it on i let the car down and noticed that its pulling the diff to the drivers side by about 2 inches past centre, which is distorting the diff to body diff
    i took it round to my mechanic today so he could use his hoist for some decent leverage and we were hanging off a long ass breaker and it wouldn't budge a mm
    just wanna know if anyone has had the same problem and how the hell I'm supposed to free it up
    every other thing is finally done and this is the only thing worrying me at this stage so id like to fix it so i can stop the car 'crabbing' along the road
    thanks alot guys :2thumbs:
    Joshua
    Mount Nelson
    Stupid question but are you turning it the right way??
    If you can't get a good grip on it I used a pipe wrench on a tie rod that didn't want to budge and it was awesome.
    Otherwise get a longer breaker bar?
    Jun 2005
    unless its reverse thread i was turning it the right way
    pipe wrench didnt cut it unfortunately
    Joshua
    Mount Nelson
    Is it a brandname panhard?
    On car adjustable?
    Does it have an adjuster in the middle or at either end?
    My tierods were reverse thread from memory. Pain in the arse those things are.
    Jun 2005
    its an AJPS on car adjustable, with the adjusting bolts in the middle
    yeah tie rods are reverse thread, not sure about these things though, i can't remember exactly which way i was twisting the free end when i put it on my car, I'm pretty sure it was normal clockwise direction :unsure:
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    get an oxy onto it. it should loosen up
    FTP.
    Veteran Nikkojoe's Avatar
    Tom
    Ok you are the 4th that has had issues with the Noltec panhard rod from ajps. Mine was rusted inside with swarth stuck in the thread.
    Used lots of crc, big adjustable spanner and breaker bars to get it undone (and all the rusted thread was exposed).
    But yeah, use oxy
    Rob
    Moorabbin
    i complained 4 times to Noltec too!
    theyve now packed up and gone to South Korea
    however any that ive fitted in the shop have never been an issue
    if youve got one recently
    they all got put in the vice, and graphite powdered
    apologies to those affected
    New ajps ones coming soon
    Veteran driftke70's Avatar
    Ryan
    Buderim
    go easy with the oxy, any temps over around 300c for an extended period, 1-2 mins will seriously weaken the alloy.
    use a penetrant, a LIGHT heat to get things moving and a nice fitting spanner with a long lever. wurth make an awesome product called rost off ice, which has never failed me, even the normal rust off has never really failed me.
    another company selling out to the global economy.
    wheelfriends.wordpress.com
  1. Panhard rod
    By jdm70 in forum Cars or Parts Wanted
    Last Post: 9th September 2010, 08:26 PM
  2. Panhard rod
    By Low Style in forum Cars or Parts Wanted
    Last Post: 9th December 2009, 06:16 PM
  3. Panhard Rod
    By loc33e in forum Cars or Parts Wanted
    Last Post: 21st November 2007, 05:49 AM
  4. panhard rod
    By DriftPlease in forum Technical - Questions
    Last Post: 11th October 2007, 07:26 PM
  5. Panhard rod
    By eightsixboy in forum General Topics (No Technical Questions)
    Last Post: 10th June 2007, 08:29 PM
