yes you can
Hey all just wondering, can you use the internals from a adm t50 in a jdm t50.
I know its a noob question but i don't want to pay a grand just to have my box rebuilt. :teehee:
yes you can
its the same same box apart from the bellhousing,
please search next time, if you have trouble because if the three letter issue use talking marks "JDM gearbox" and set it to the technical section only, that should get you started
thanks for that its just that i heard otherwise because of bearings and the slave cylinder.
cheers for the help.
slave cylender is on the bellhousing and is different
Is it a JDM box that is dead? Cause if so why not just swap the bellhousings from the ADM one you buy to your JDM housing or the other way around for that matter.
