They are the same thing
hey,
i was wondering, if i can use my S series drums OR shoes on my T series, i have just pulled the drums off prior to installing (and welding) it, and they look bad, i was wondering since the drums seem to be a very similar size (if not the same) if i can move the shoes across,
i was about to try this myself, then it started raining badly and i had to abandon it, so i thought i would just post up the question to hear from someone who would already know..
cheers,
Albert
if thats the case, can i move the whole brake housing thingos from the S series axel onto the T series one, that way i retain the original length brake cables and also have my much more meaty shoes and drums....
i'll try this tomorrow and let you know how i go, but if anyone knows tonight, that'd be great.
I did the same thing mate
Hi ive just been asked if a friend can put his S series ADM sprinter diff into his AE71 i guessing he needs the sprinter rear tail shaft and use the AE71 front shaft? will these mate together ? or should he use the whole spinter assembly into the AE71.
Ive been told all pinions on toyotas of this type are interchangable but not concrete info.
Ive done a search but only covers T series diff's.
pretty sure you can use a whole 86 tailshaft, after all their both same spline t50s and 86 has and s series so yeah
PROTEK TYRE AND AUTO
SQ ENGINEERING
NCCE
