Results 1 to 7 of 7
Thread: KE70 tail lights to T-18
    Senior Member stouty's Avatar
    Leigh
    Forster
    Default KE70 tail lights to T-18
    I know some ppl use T-18 tail lights on there KE70 so im persuming KE70 lights will fit T-18. Seems a stupid question i know but just want to make sure before i buy some. Cheers
    Grip TE72
    http://www.ae86drivingclub.com.au/fo...read.php?t=276
    AJPS for all you Toyota goodies
    West
    They fit the recess in the body but you will need to redrill another set of holes to fit them. Its not hard.
    Leigh
    Forster
    Sweet cheers man
    Grip TE72
    dan
    adelaide
    adelaide
    whats needed to fit t18 tail lights to a ke70?
    Veteran shift_rook's Avatar
    SE Burbs
    redrill the holes, pretty easy
    Veteran stahlz_ae86's Avatar
    Paul
    From memory the backings on the KE70 DX lights i had were too large to fit in the opening for the lights in T-18. Never intended to fit them but i needed to drive the car to my bro's place down the street and didn't wanna look too sus. So that's only from memory at a quick test fit. If you've got a mate local with a KE I'd suggest test fitting before buying, or if you wait I can re-check that for you with both kinds of KE70 tails in my T-18 when i get a chance.
    Leigh
    Forster
    Yeh that would be good stahlz ae86 cheers.
    Im keen on doing it just for a differnet look someone out there might be keen to do a straight swap for the same reason.
    Grip TE72
  1. ke70/ae71 Tail Lights
    By Lancerdup in forum Cars or Parts Wanted
    Last Post: 1st April 2011, 11:54 AM
  2. Replies: 13
    Last Post: 4th April 2010, 12:25 PM
  3. T-18/TE72 Tail Lights
    By alex.wilson in forum Cars or Parts Wanted
    Last Post: 17th November 2009, 03:21 PM
  4. ke70 tail lights
    By Ke70alex in forum Cars or Parts Wanted
    Last Post: 16th November 2009, 04:49 PM
