Results 1 to 8 of 8
Thread: changing points, what is the correct gap?
    Senior Member Ade_Mc's Avatar
    Ade
    SYD, Inner west
    Default changed points.....was running great, next morning won't start!!!!
    hi,
    i repalced my points, dizzy cap, button and leads yesterday on my 4AC.
    and it was running sweet.
    got up this morning to drive to footy....and it won't start.
    it ticks over but doesn't ignite.
    seems that i might not be getting any spark??? but i don't know for sure.
    i unplugged the main lead from the coil, and don't seem to get any spark(as i was holding the metal connector end and didn't shocked.
    a mate of mine told me that coils rarely die, so my question is what do i do next?
    -i've checked the fuses...all good.
    -gap is good...set at 0.45
    -leads all plugged in correctly
    -sparks are practically new
    so what does anyone think it could be? as i am stumped!
    could it be the coil?
    condenser?
    any help would be awesome, as i kind of need to fix the car ASAP.
    Ade
    SYD, Inner west
    Default ...its ok did some research and found some answers.
    found some info.....hope this helps others
    Owners Manual states: 4AC engine Australia uses 97 octane and 4AGE engine uses 98 octane. Just incidental information for you.
    The Service specs are: Ignition timing 4A & 4AC engine; 5 deg btdc @ (MAX 900 rpm auto). Distributor rubbing block gap; 0.45 mm (0.018")
    Dwell angle; 52 degrees. Spark plug gap 0.8 mm(0.031") NGK; BP5EY or N12YC. points GD214
    Engine O'haul Manual & experience says for Nippondenso maggie: dwell between 46 and 58 (52) degrees. rubbing block gap 50 deg=(0.011") & 48deg=(0.012").
    Timing set 3-7 deg BTDCat idle speed of 750rpm. And set the damping-spring gap to 0.1 to 0.4 mm (0.004 to 0.016"). with vacuum advance connected to the ported pipe on the carby.
    Jonathan
    You can measure the actual gap between the points when they are open, or you can measure the rubbing block to shaft gap when the points are closed. Either method seams to work.
    You can check and adjust this with a dwell meter but that may be hard to find. I don't have a dwell meter, but maybe I should.
    You can bump the ignition timing up to 10 degrees if you want.
  • #4
    Ade
    SYD, Inner west
    hi,
    condenser?
  • #5
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Quickest and easiest fix would probably be to just go grab an electronic dizzy out of a 4AC AE82 and bin the points all together.
  • #6
    Ade
    SYD, Inner west
    Quote Originally Posted by Golberg View Post
    is it just a direct swap?
    i'll see how much it will set me back.
  • #7
    Lawrence
    Wollongong
    Yeah, I think you'll have to mod the wires slightly, but everything bolts together fine.
  • #8
    Ade
    SYD, Inner west
    sweet, might head to the wreakers and see if i can pick one up.
    does anyone know what wires i need to mod or has anyone done a write up/tech article?
  • Similar Threads
    1. Points Gap
      By sonsta in forum Technical - Questions
      Last Post: 12th July 2009, 11:42 PM
    2. what the gap in the dizzy suposed to be ?
      By mtgg85 in forum Technical - Questions
      Last Post: 14th July 2008, 11:59 PM
    3. Spark and Points gap (help needed!)
      By grape_moosha in forum Technical - Questions
      Last Post: 3rd June 2007, 08:10 PM
    4. 4-AC POINTS GAP??
      By superbmobile in forum Technical - Questions
      Last Post: 9th December 2006, 02:24 AM
    5. points gap
      By delazy in forum Technical - Questions
      Last Post: 30th June 2006, 07:33 PM
