Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: dash light issues
    Senior Member trueno85's Avatar
    Ayden
    Silverwater
    Default dash light issues
    wierdest thing happend i turned off my car went to a shop for ten minutes then came back to start it again then i noticed when i was driving that the battery light and rear lights light was still on even though it was fine. Then i realised that when i revved over 3k all of them turned off including the headlights light (it was night) then came back on under 3k. eventually after like 10 minutes they turned off for the rest of the trip even the headlight light
    does anyone have any idea why this would happen? also its a digital dash standard if that helps! no other lights dimmed of anything else affected
    Glenn ke_70's Avatar
    Clay
    Barossa!
    happened 2 me 2 but when i braked they came on
    Steve
    Cairns
    Whenever I see those lights come on, I turn off every unnecessary electrical item and make a dash for home as I know the alternator has failed and there's not long before the battery runs out, the ecu shuts down and its game over.
  • #4
    Site Supporter Javal's Avatar
    Josho
    Quote Originally Posted by ke_70 View Post
    Completely different problem. Yours would have been caused by a bad earth on the taillight loom.
    Quote Originally Posted by 86coupe View Post
    Agreed with this. Your alternator is not charging. Could be a number of problems with it, but you're probably going to have to replace it.
    First of all though, do the visual inspection - make sure none of the wires have come off the back, and that the battery terminals are done up nice and firmly.
  • #5
    Ayden
    Silverwater
    oh really? okay then have to figure out what to do! so even though they turn off again at 3k revs it will be the alternator going?
  • #6
    Senior Member trueno's Avatar
    Nik
    North side
    yer alternator is about to go.it happen to me once
    AE86 JDM TRUENO
    FULL JDM EP91 GLANZA V (REPLICA)
    EP82 GT TURBO[SOLD]
    EP91 GLANZA [SOLD]
    AE82 FX GT [SOLD]
    S13 SR20DET SILVIA [SOLD]
  • #7
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Quote Originally Posted by trueno85 View Post
    Think of it this way, at 800 rpm (standard idle) those lights shouldn't be on. So in otherwords at 800rpm the alternator should be charging enough to keep the light off. If the lights stay at anything below 3000rpm it means it having to spin the alternator all the way up to high speed to just scrape enough power to avoid the charge light coming on. So even at 3000rpm its at minimal charge. It'll only get worse, and usually very quickly, alternators quite often just let go in one hit.
    So in all seriousness don't drive the car until you have got the alternator looked at. Otherwise you will almost definitely get stranded somewhere with a flat battery and a non-charging alternator = not going anywhere on its own steam, even with a jump start.
  • #8
    Clay
    Barossa!
    Quote Originally Posted by Javal View Post
    wouldnt happen 2 know where the earth is just quick (save me an hour of fuckin round)
    sorry 4 usein ur thread
  • #9
    Lawrence
    Wollongong
    Off the top of my head, I think there might be one just under the RHS tail light.
  • #10
    Clay
    Barossa!
    cheers mate
  • Page 1 of 3 1 2 3 LastLast
    1. Electrical issues - Dash, parkers, tail lights not working in Ke70
      By Low Style in forum Technical - Questions
      Last Post: 18th April 2013, 05:51 PM
    2. KE70 Electrical Issues (Clock and interior light not working)
      By tanKE70 in forum Technical - Questions
      Last Post: 13th June 2012, 04:14 PM
    3. Replies: 1
      Last Post: 29th June 2011, 04:24 PM
    4. Head Light issues
      By Blizzerd in forum Technical - Questions
      Last Post: 18th September 2009, 08:07 PM
    5. WTB: Light switch, dash light plug, roof clips
      By li21 in forum Cars or Parts Wanted
      Last Post: 18th May 2008, 10:08 PM
