Results 1 to 2 of 2
Thread: gearbox troubles
    Alistair
    Cleveland
    Default gearbox troubles
    Gday, new problem.
    i cant get 3rd gear when i am changing down from 4th. it goes in wen i am slow enough to go into 2nd. it also goes up through the gears ok. any thoughts?
    Jonathan
    3rd gear syncro is worn. You will be able to get 3rd gear if you double clutch, (which requires you to rev the motor a fair bit with the stick in neutral and the foot off the clutch).
  • Similar Threads
    1. Gearbox troubles
      By MattAE71 in forum Technical - Questions
      Last Post: 5th August 2010, 08:01 PM
    2. Engine troubles
      By Bart in forum Technical - Questions
      Last Post: 18th April 2009, 10:02 PM
    3. Boosting troubles
      By AE71 Rolla in forum Technical - Questions
      Last Post: 5th August 2008, 11:48 PM
    4. ALTERNATOR TROUBLES...
      By Blair in forum Technical - Questions
      Last Post: 22nd February 2008, 06:23 PM
    5. wiring troubles
      By cmesld in forum Technical - Questions
      Last Post: 14th April 2007, 07:59 AM
