Results 1 to 3 of 3
Thread: JDM caliper reseal
    Veteran starni_boy's Avatar
    Clint
    Sutherland Shire
    Default JDM caliper reseal
    So I've repainted my JDM calipers and I am about to put the rest of the seals back in, all brand new.
    Just need to know what order the seals go in around the piston from factory. Obviously the expanding one is the last, but I'm not sure about the other two.
    If someone could scan a service manual or something that would be great.
    Veteran hao.'s Avatar
    Hao
    South Brisbane
    Here you go. Hopefully this can help you out.
    Jonathan
    First of all get the cailiper and all parts clean and dry, with no gunk or rust in the groove where the seal goes. Get the piston clean and dry, and pollished smooth with a rag. (Don't use sandpaper or anything on the piston, but it will survive some wire wheel action if needed. It is hard-chrome, I think). If there is oil or grease on anything, clean off with brake cleaner. Don't let oil or grease get near the seals. Lube everything with rubber grease only. Put the main square seal in first. Then push the piston all the way in. Put the dust seal on, making sure it gets in it's groove. Place the metal circlip in the groove, which holds the dust seal in place.
  • Similar Threads
    1. WTB: JDM front right caliper
      By svenmate in forum Cars or Parts Wanted
      Last Post: 30th May 2011, 02:58 PM
    2. JDM rear caliper problem
      By haydenz in forum Technical - Questions
      Last Post: 10th June 2010, 11:39 PM
    3. WTB JDM caliper brackets
      By deanoo in forum Cars or Parts Wanted
      Last Post: 24th June 2007, 09:17 PM
    4. JDM caliper rebuild
      By robert nguyen in forum Technical - Questions
      Last Post: 5th June 2007, 09:16 PM
    5. Left JDM rear caliper
      By MiC in forum Cars or Parts Wanted
      Last Post: 20th May 2007, 10:30 PM
