Results 1 to 6 of 6
Thread: 4A-GE smallport ECU wiring
    Veteran stahlz_ae86's Avatar
    Paul
    Default 4A-GE smallport ECU wiring
    Hi all, just in the process of tidying up a loom for a smallport conversion into KE70.
    There's 3 slots on the ECU, a large 26p, medium 16p, and a small 12p.
    Now I have the 26 and 16, but went to the wreckers thisarvo to raid the toyota's for the right plug to go in the 12p slot. I pulled the ECU out of a 93 widebody V6 Camry and took 3 of the 4 plugs from that, a 26, 16 and a 12. Problem still lies in the fact i have not got the correct 12p plug as the spacing of the pins is wider on the smallport ECU than that of the Camry.
    Does someone know what model Toyota I would be able to raid next for the correct plug to use in that slot? There's obviously no SX Corolla's at pick-a-part so I'd like to find it on a more common model.
    Paul
    For the record the 16p and 26p plugs from the V6 Camry ECU fit the smallport 4A-GE ECU. V6 Camry 1993-1996.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Umm, look at a late 3S-FE camry (SV21) early ones definitely don't have the correct plug (they're the same a big port ECU's), but I'm pretty sure 89-90 should have all the same plugs as a smallport ECU.
  • #4
    Paul
    Cheers, going to the other wreckers thismorning to sus it out, I'll let you know how i went.
  • #5
    Paul
    Got the correct wider pinned 12p plug thismorning. It came from a Dec '93 widebody camry sedan with 5S-FE. The Nov '93 widebody Camry wagon I checked had a different computer again, so i don't know if all pre November 93 ecu's have all got different ecu pinouts to all Dec 93 onward ones but that would be my guess.
    All SV21 Camry's I looked at seem to have the yellow plugs which I think may be the same as bigport 16V 4A-GE. From memory the 3 plugs had the same amount of pins so i guess anyone who needs that gear for a bigport conversion can keep that in mind when they get to that stage.
    The Dec '93 widebody Camry I pulled the 12p from also had the same 16p and 26p so if you need a full set of ECU plugs that's the model I suggest people to look for if they need a complete set of 3 plugs to do a smallport 16V ECU install.
    Hope this info can help others in the future.
  • #6
    Lawrence
    Wollongong
    Yeah the earlier SV21's have all the same plugs as the bigport ECU. I was almost certain the later ones had the newer plugs. I'm sure that some sort of car with a 3S-FE has them at least.
  • Similar Threads
    1. 16V exhaust, smallport 4A-GE, other stuff.
      By Faceplant456 in forum Car Parts For Sale
      Last Post: 16th November 2012, 11:59 PM
    2. 4A-GE smallport head
      By Shrek in forum Cars or Parts Wanted
      Last Post: 9th March 2012, 12:59 AM
    3. 4A-GE Redtop Smallport *needs rebuild*
      By erik in forum Car Parts For Sale
      Last Post: 17th October 2011, 12:41 PM
    4. Wiring Dilemna... (16V 4A-GE)
      By Victim in forum Technical - Questions
      Last Post: 25th February 2010, 09:10 AM
    5. 4a-geu ecu pinout same as ae82 4a-ge?
      Last Post: 25th November 2009, 05:21 PM
