Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: Wheel widths and offset for my hachi
    Veteran drift kid's Avatar
    Glossodia
    Default Wheel widths and offset for my hachi
    hey, im gunna buy a set of wheels, and im wonderin what width and offset would look tha best on my hachi, i want em to be pretty flush with tha guards (im gunna flare em eventually). thanx =] in new to this so some advice would be great.
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    if u just want to lip your guards so flush wheels will fit id go
    front -14/15x7.5 -5 or more
    rear -14/15x8.5 -2 or more or for rear u could just go 8 with more neg offset
    Glossodia
    so is that -14 offset or -5 offset? sum 1 fill me in on all these numbers? im not gettin it, tha 15x7.5 is dia and width, but what r the other numbers for?
    Ade
    SYD, Inner west
    RIM SIZE 14-15inch is ideal.
    7.5-8.5inch wide will fill the guards adequately.
    -2 to -5 offset, depending on width.
    the higher the negative offset is......the deeper the dish will be.
    Glossodia
    so -5 is bigger dish than -2, kool, so if i go with -5 offset, what width should i run?
    Just Half Steppin
    considering you said you wanted to flare your guards then i would suggest buying wheels now to suit them flared...
    15x8 -10
    15x9 -13
    that will flush up flared gaurds on a sprinter
    Glossodia
    but what is your defenition of "flared", i just wanna make em lil bigger, prob just lip em.
    Glossodia
    i was just thinkin of 7.5 on front and 8's on rear with -3 front and -5 rear
    性交を愛する
    Go 8's on the front with -5 or so. Will fit easy with negative 3 deg of camber.
    And like 8 -10 on the rear.
    Also depends on how low you are going.
    Glossodia
    is it hard/expensive to get more camber, im running stock susp, gunna lower it tho
  1. Wheel offset calculator
    By Jarrod in forum Technical - Articles
    Last Post: 23rd September 2008, 07:06 PM
  2. Wheel Offset Calculator
    By 741 in forum General Topics (No Technical Questions)
    Last Post: 16th December 2007, 03:49 PM
  3. rim widths
    By kurtis in forum General Topics (No Technical Questions)
    Last Post: 3rd February 2007, 10:36 PM
  4. Wheel Offset
    By nightdevil in forum Technical - Questions
    Last Post: 4th December 2005, 09:46 AM
