if u just want to lip your guards so flush wheels will fit id go
front -14/15x7.5 -5 or more
rear -14/15x8.5 -2 or more or for rear u could just go 8 with more neg offset
hey, im gunna buy a set of wheels, and im wonderin what width and offset would look tha best on my hachi, i want em to be pretty flush with tha guards (im gunna flare em eventually). thanx =] in new to this so some advice would be great.
so is that -14 offset or -5 offset? sum 1 fill me in on all these numbers? im not gettin it, tha 15x7.5 is dia and width, but what r the other numbers for?
RIM SIZE 14-15inch is ideal.
7.5-8.5inch wide will fill the guards adequately.
-2 to -5 offset, depending on width.
the higher the negative offset is......the deeper the dish will be.
so -5 is bigger dish than -2, kool, so if i go with -5 offset, what width should i run?
considering you said you wanted to flare your guards then i would suggest buying wheels now to suit them flared...
15x8 -10
15x9 -13
that will flush up flared gaurds on a sprinter
but what is your defenition of "flared", i just wanna make em lil bigger, prob just lip em.
i was just thinkin of 7.5 on front and 8's on rear with -3 front and -5 rear
Go 8's on the front with -5 or so. Will fit easy with negative 3 deg of camber.
And like 8 -10 on the rear.
Also depends on how low you are going.
is it hard/expensive to get more camber, im running stock susp, gunna lower it tho
