Results 1 to 8 of 8
Thread: r31 diff in2 ke70 + 31 coil overs
    Glenn ke_70's Avatar
    Clay
    Barossa!
    Default r31 diff in2 ke70 + 31 coil overs
    i hav a pair of r31 coil overs sitin around
    just wondering how do u put the r31 diff in is it just a case of choping all the 31 mounts off and reweldin the ke 1s on? and does it need shortning?
    and the main question do i use the r31 coil overs or will i hav 2 get the ae/ke coil overs 2 fit?
    and wot sort of power can u throw at these as well i know it only a 4k now but id like 2 keep it 4 when i upgrade
    Veteran bigm's Avatar
    Gold Coast
    you will never break a r31 diff in a ke70.. never
    yes you have to change the mounts over from the ke70 ones. the diff gives you 30mm track increase each size so fitting descent wheels under the stock guards is not gona happen.
    but dont bother with the 4k, waste of time.
    with the 31 coilovers you need to modifiy the top mounting point. cutting the current one out and welding in a new plate big enough with the correct holes is what need to be done. you will need to check the length of them, that will determine where they are mounted.
    stefan
    vic
    eastern suburbs
    ud have to get smaller diameter custom springs made for the coilovers, otherwise youll need to hack up the strut towers to make them wider
  • #4
    Senior Member corey70's Avatar
    Corey
    my 31 diff is currently getting made up for my ke, theyr cutting the tubes off the ke diff and welding them onto the 31 diff centre so dont have to worry bout getting all the mounts sqaure ect which would be alot of work, apparently this is how the toyoland one was done and it turned out really well.
    they said they can safely take 10mm off each side safely without having to re-spline and heat treat it..
    mine will just be rolla suspension still tho..
  • #5
    Corey
    btw boss automotive is doing it
  • #6
    Davey & Riki-lee
    South Australia
    Seaford SA
    how much are they charging to swap just the mounts from one diff to the other?
    Our introduction - Click here
  • #7
    Corey
    for them to change the mounts, shorten it and to supply/instal minispool is bout $1000
  • #8
    Corey
    i read another thread somewhere where a dude paid $1800 for the same thing
  • Similar Threads
    1. R31 rb30et, coil overs, track ready, Gold Coast
      By ae86 slide in forum Cars for Sale (Not Toyotas)
      Last Post: 4th November 2012, 11:03 AM
    2. Replies: 0
      Last Post: 24th June 2012, 12:57 PM
    3. please help me- diff nose hitting body + T3 coil-overs anyone?
      By adam_loves_hachi_roku in forum Technical - Questions
      Last Post: 25th January 2010, 03:10 PM
    4. KE70 4age, coil overs
      By whereismydrifttoy in forum Cars for Sale (Toyota Only)
      Last Post: 16th November 2009, 08:03 AM
    5. stiff shocks & springs to suite ke70 or coil overs
      By green_boy_91 in forum Cars or Parts Wanted
      Last Post: 25th January 2007, 03:31 PM
