Results 1 to 7 of 7
Thread: Does standard JDM exhaust mani foul ADM bearbox?
    Senior Member stylz's Avatar
    Art
    Melb
    Default Does standard JDM exhaust mani foul ADM bearbox?
    as topic states, just wondering if a standard JDM exhaust manifold fouls on the ADM gear box, the slave cylinder mainly as on the JDM box its on the other sides
    VLNY
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    no..............
    BENT MECHANIX - Garage 20:
    Art
    Melb
    ok.....
    VLNY
  • #4
    Art
    Melb
    seeing as im a paranoid person, i just want to double check that it clears :p
    my worries are that because the JDM box has the clutch slave on the drivers side, that the JDM exhaust will hit the clutch slave on the ADM box becuase its on the passenger side :o
    can anyone else clear this up for me? thanks
    VLNY
  • #5
    Senior Member adam's Avatar
    Adam
    Don't know if this will help, but the TRD copy extractors clear the ADM slave, but hits the clutch line bolt. It's easily fixed when replaced with a banjo bolt though.
    I can take a photo of how much it clears (10-15mm clearance from memory) if you'd like.
    Previous ride: 4AGE powered KE70.
    Current: JZX100 Chaser and '73 Datsun 240z.
    http://twofortyzee.wordpress.com
  • #6
    Niz
    South~Slide Briz
    no... hence the reason I said no in the first place FFS.
    I ran a JDM manifold and an ADM box and it clears easy... have a W55 now though so the slave is on the drivers side...
  • #7
    Art
    Melb
    well next time how about you say something like that instead of saying just no. a simple explanation is all i needed
    VLNY
  • Similar Threads
    1. Standard AE86 wheel sizes JDM/ADM?
      By RobertoX in forum Technical - Rims & Tyres
      Last Post: 29th June 2011, 02:52 PM
    2. Replies: 1
      Last Post: 17th September 2010, 10:05 PM
    3. random thread: did some one from SA buy a HKS exhaust mani and gate recently??
      By slide86 in forum Adelaide & SA Events and Discussion
      Last Post: 18th May 2010, 10:52 PM
    4. Replies: 2
      Last Post: 10th May 2010, 11:01 PM
    5. WTB: RWD exhaust mani flange or extractors.
      By Jazz9 in forum Cars or Parts Wanted
      Last Post: 17th April 2007, 05:09 PM
