Results 1 to 9 of 9
Thread: Fuel pump relay
    Veteran v-tec's Avatar
    Grant
    Gold Coast
    My fuel pump relay is cactus, and seeing as its a gay toyota thing that i can only get from toyota I'm thinking of just not using it.
    Its been suggested to me to just run the positive feed straight to it, and at the same time have an in cabin switch for it
    Whats stopping me from doing this, as it sounds like a good idea.
    The pump is a vl pump so nothing too serious.
    Grant
    Mar 2006
    i've used a seperate switch in the past for a fuel pump.
    The only thing i did differently was run the power (high amp) cable to a 5 buck relay, then to the pump,
    and have a trigger line to the switch in the cabin.
    I wouldn't run 40amp wire and switch into the dash.
    if not using the ecu trigger line, make sure your prime (3 seconds) before you start!
    Ryan
    qld
    brisbane
    Aust.
    i had that exact setup a few weeks ago, but then changed back to the relay because if you fuckup / prang your car, fuel is pissing out everywhere.
    but otherwise, don't use tiny wire, and it shall be fine.
    Grant
    Gold Coast
    i see, so the relay actually controls the pump to run when the car is firing?
    I'm a bit of a wiring noob, so finding it a bit hard to grasp.
    But i think thats the main idea of having a switch so i can turn it off if i have a crash...
    So basically, if i don't run a relay i have to wait for it to prime the fuel rail before starting? Ie instead of the relay doing what it should
    Dave
    yeah don't run a seperate switch, run it from the ecu. (you don't want to be unconscious after having a prang and have fuel goin everywhere do ya)
    there is a pin on the ecu, that will turn on the pump when it needs to be.
    what you can do though...is use this wire to trigger a relay that sends power to the pump VIA a positive cable straight from the battery.
    its essentially the same as what you do when you wire up an amplifier or even driving lights, the power comes directly from the battery, but its switched via the appropriate method (in the amplifier case it turns on with the CD player, and in the driving lights setup the turn on on high beams etc)
    if you woudl like me to draw up a diagram on how to wire it up with a normal automotive relay....i can...but not now...gota go to work...
    - Blaise Pascal
    Leigh
    Penshurst
    I was wondering the same thing a while ago and most people I spoke to said to do it properly
    I'd hook it up to the ECU (pretty sure it's a ground switch) and use relay coz if you are in a stack you really don't want fuel pissing everywhere cause the whole lot could go up
    I've also added in a fuel cut switch for a bit of security
    there was a thread a few months ago with a wiring diagram in it
    I would vote for doing it properly
    Leigh
    Veteran Nikkojoe's Avatar
    Tom
    I lost my other wiring diagram i made a few months back, but here is a quick one i made up.
    Elite rthy's Avatar
    Leo
    Tulla
    just rip the relay and plug out of another toyota, I used a local 16V relay for my 20v ecu and ground a few plastic locating pins off to make it fit.
    Grant
    Gold Coast
    Got a new Relay from just toyota for $10, thanks guys
  1. Fuel pump wiring - extra relay?
    By 70XIN in forum Technical - Questions
    Last Post: 15th June 2012, 08:48 AM
  2. 4AC fuel pump - replace mechanical pump or put in eleectic pump?
    By Sprinterman in forum Cars or Parts Wanted
    Last Post: 19th March 2012, 07:57 AM
  3. Wire up my Alternator, Starter motor and Fuel pump relay!
    By DRFTAE86 in forum Melbourne & Vic Events and Discussion
    Last Post: 15th March 2010, 12:19 PM
  4. [VIC]: 4AGE Fuel Pump Relay
    By khoala in forum Cars or Parts Wanted
    Last Post: 3rd March 2010, 02:11 AM
  5. What kills Fuel pump relay's??
    By v-tec in forum Technical - Questions
    Last Post: 30th September 2008, 02:06 AM
