You sure its 175? Mine is 180 and it fits no problem with the same tensioner.
How are you trying to get the belt on? What size belt are you using?
i have just put on a 175mm custom crank pulley,but put on a hyundai ep016 a/c pulley to use as the tensioner pulley but it is a fraction to big cause i can't get on a new belt!can someone tell me a smaller pulley to use or how to solve this problem?cheers matt
yeh sure its 175 mm this is what my mechanic is telling me he said there is only like 1to 2 mm gap between the crank pulley and the idler and the belt is like 3 mm and can't get it on so need o smaller idler!
I always pull my idler off, slip the new belt on then push the idler back on. There is not much of a gap, but it works well. Try dropping the adjusting bolt of the idler lower so you can get the belt on easier.
Other then that, not sure whatelse....
Can get a pic if you want?
yeh a pic would be great!so you have had no prolems with the belt snapping or anything?
Will get a pic tomorrow hopefully. No problem with the belt snapping.
Its like a 2-3mm gap when the pulley is on so you need to remove it first in order to put the belt on.
<div class='quotetop'>QUOTE (Nikkojoe @ Aug 15 2008, 06:14 PM) </div>are you suggesting you're using the standard tensioner pulley with a 180mm crank pulley??
Here is a 180mm crank pulley with smaller idler pulley (tensioner) its a damn tight fit.
And here's the difference stock and the smaller pulley... so I don't see how 180mm crank pulley+stock idler works...
No, I'm using the same ep016 idler.
No way in the world would the stock one would work.....
My water pump pulley was machined down too. The gap in your pic looks exactly like mine....
ah k righto, that makes sense.
