Results 1 to 2 of 2
Thread: external thermostat - what in/outlet is what?
    Senior Member Dongaz's Avatar
    Cameron
    The Gap, Brisbane
    Hey can some one post up what outlet goes to what for me.
    Any pics on a car would be good to.
    I want to run the heater hoses aswell, I don't know if that makes a difference to what goes where.
    No aircon though.
    Its a 4agte (ze) block in an AE86
    Nathan
    Lilydale
    the large long pipe thats aiming the same was as the little one under it goes to the back of the water pump(you just cut the original steel pipe off a couple of inches back).
    The small pipe facing the same direction goes to the thinner pipe above the water pump off the head. again, cut it to length.
    The other large pipe with the sensor hanging out goes to the Radiator bottom pipe.
    the last one goes to the 'drivers side' heater core pipe.
    and then you connect the heater tap to the back of the head and ure done!
  • Similar Threads
    1. KE70 external sunvisor
      By blzbub666 in forum Car Parts For Sale
      Last Post: 4th August 2012, 07:29 PM
    2. external wastegate help please???
      By ae86-13b in forum Technical - Questions
      Last Post: 31st May 2010, 11:02 PM
    3. What external fuel pump to use
      By 4agze-hachisaurus in forum Technical - Questions
      Last Post: 20th October 2006, 07:25 PM
