Results 1 to 8 of 8
Thread: Weird Idle.
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    Default Weird Idle.
    Well, so the story is i got some new cams put in my car yesterday and it was running at around 800 - 1000 rpm which was normal, but then thismorning i started it up and it was running around 1500 - 2000...
    Mind you it still needs a tune.
    Anyone know what could be going on?
    any help would be much appriciated!
    Cheers,
    Jordan.
    Jordan
    Sunshine Coast
    Anyone?
    Senior Member hilux05's Avatar
    Richie
    Sunshine Coast
    mine used to do that every now an then but it didnt have cams. all it was was the tb spring wasnt strong enough to close it properly so a quick jab of the loud pedal an she'd drop down to about 800-1000..
    but was your motor a little warm or cold after you put the cams in??
  • #4
    Jordan
    Sunshine Coast
    Yeah ive tried the quick jab trick lol but still nothing, I couldn't tell you as i didn't put my cams in.
  • #5
    Dave
    Quote Originally Posted by gumbie View Post
    id say that has a fair bit to do with it. but you say its varied with the tune staying the same.
    the only way for an engine to change rev is to either let more air in, or for the ign timing to be advanced.
    so id first start by checking the ign timing, but its more likely to be air getting let in somewhere. so id be checking for leaks anywhere, if you still have the coolant opperated idle up thing then maybe that is playing up? also maybe your tps is out of adjustment as well, as i know if i fiddle with mine the idle goes up and down etc.
  • #6
    Jordan
    Sunshine Coast
    Thanks for that mate, will have a look at it once I've finished work
  • #7
    Jordan
    Sunshine Coast
    Well i had a look around but got abit dark outside and couldn't find any leaks.. Any other suggestions?
  • #8
    Elite rthy's Avatar
    Leo
    Tulla
    hunting idle
    Leak in the intake, air in the water system, TPS, BHG, etc
  • Similar Threads
    1. Weird Idle
      By Felix in forum Technical - Questions
      Last Post: 27th September 2008, 12:40 AM
    2. Weird problem
      Last Post: 12th August 2008, 11:25 PM
    3. Weird foods you like
      By Corolla_Gurl in forum Offtopic Discussions
      Last Post: 16th January 2008, 12:38 PM
    4. WEIRD PROBLEM
      By AE71_Rolla in forum General Topics (No Technical Questions)
      Last Post: 12th March 2007, 07:50 PM
