Results 1 to 3 of 3
Thread: earthing points on a ke70
    Glenn ke_70's Avatar
    Clay
    Barossa!
    Default earthing points on a ke70
    ok where r all the earthing point in my ke70?
    there is 2 random black and yellow wire on my gbox 1 towards the back screwed on just chillin there does this go on the chassis anywhere
    and the other is a black and yellow goin from the chassis 2 the gbox through a bell housing bolt
    if it make any difference i did a auto 2 man convo
    cheers guys
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Go hunting for them, there are plenty. Almost all earths are white with a black trace (Apart from some of the thicker ones which go between mechanicals and body, which are black with a yellow trace). If its either of those with eyelet (the round hole type connection) and its disconnected, bolt it down to something metal.
    That one on the glove box just sounds like the one for the factory radio, which I'm guessing you're not using, so it doesn't matter.
    If you're still having problems, take it to somebody who knows what they are doing, and owns a multimeter.
    Clay
    Barossa!
    gbox = gearbox and i hav a multimetre and ive given up
    thanx anyway man
  • Similar Threads
    1. Jdm Ae86 Ultra Leads Earthing Kit
      Last Post: 3rd March 2012, 11:12 AM
    2. FS: Full coil over for AE86/KE70, Aftermarket 4AGE ECU, Earthing kit
      By charlie_keto in forum Car Parts For Sale
      Last Post: 6th July 2010, 07:47 PM
    3. 16v earthing
      By Tim.duncan in forum Technical - Questions
      Last Post: 29th July 2009, 11:41 PM
    4. Points Gap
      By sonsta in forum Technical - Questions
      Last Post: 12th July 2009, 11:42 PM
    5. earthing kits????
      By ae86dave in forum General Topics (No Technical Questions)
      Last Post: 22nd May 2006, 12:45 PM
