Results 1 to 6 of 6
Thread: ebay turbo manifolds
    Nic
    Mt Evelyn
    Default ebay turbo manifolds
    hey guys, just wondering if anyone here is using one of those ebay cast manifolds for 4age. just wondering if they seem to fit and work fairly well? also any pics of firewall clearance would be good.
    nic
    Moderator Frak's Avatar
    Jamie
    The ebay cast 4age manifolds are a copy of the HKS manifold, I used a genuine HKS manifold on my 20V turbo, I guess the chinese just copied it but used crap metal. The HKS cast manifolds have a high nickel content. If you shop around the genuine HKS manifold doesn't cost much more.
    Hachiroku since 1994
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    the ebay ones are prone to cracking but this is easily fixed if you brace the manifold by welding a bracket to the engine bay to manifold
  • #4
    Junior Member bounceae86's Avatar
    the cast one dosnt look like it will crack at all,does anyone know where to get a down pipe as the turbo sits upside down with there and down pipe wants to go up
  • #5
    Veteran Nikkojoe's Avatar
    Tom
    I'm going to be running one, have no clearance issues with it. Finish wise it looks quite good, though the split pulse isn't right. You need to get a custom made dump (buy a flange and get an exhaust shop to weld you one up).
  • #6
    Veteran Konakid's Avatar
    Henry
    Eastern
    Quote Originally Posted by riojin View Post
    ....or just buy a Kelway one and it will last forever and fit sweet for the turbo you want to run.
  • Similar Threads
    1. Replies: 6
      Last Post: 6th February 2011, 05:14 PM
    2. Turbo manifolds!!
      By dr1ft-pig in forum Technical - Questions
      Last Post: 21st September 2009, 10:19 PM
    3. Decent Turbo Manifolds
      By PuGZoR in forum Technical - Questions
      Last Post: 7th October 2006, 11:12 PM
