Results 1 to 2 of 2
Thread: Trev's Guide To Repairing 4age Dizzy Wiring
    Trev
    Queensland
    Redbank Plains
    Hey guys, The other day i had to find a way to repair broken dizzy wiring on a 4age so i just cut the wiring down and repinned it, I did the same thing to my car today when i made the wiring harness so i thought id do a step by step guide for the FAQ.
    Pictured is the plug with broken/exposed wiring:
    Tools required (3mm heatshrink, Lighter or heatgun, Narva plug connector pins, Plug connector crimpers):
    Step 1, Cut off the wires and remove the grommet:
    Step 2, Remove old female terminals by using a skinny pointed object to push on the holding tab while forcing the terminal out of the back of the plug:
    (Picture of holding tab):
    Step 3, Identify the wire locations on the distributor plug (makes it easier when putting the grommet on):
    Step 4, Slide the grommet back onto the wiring harness:
    Step 5, Put heat shrink on the wires so that approx 1cm of wiring is showing and shrink it:
    Step 6, Pull the grommet back over the now heat shrink coated wiring:
    Trev
    Queensland
    Redbank Plains
    Step 7, Crimp terminals onto the wiring:
    You will end up with it looking like this:
    Step 8, Insert the terminals into the plug and push the grommet back into the plug:
    Final step, Once you have done that you will have a plug that has no breaks or exposed wiring that will be stronger than it previously was:
  1. HOW TO: 4AGE into ADM AE86/AE71 Wiring guide
    By Nikkojoe in forum Technical - Articles
    Last Post: 21st April 2019, 10:31 PM
  2. 4ac dizzy/coil wiring help
    By rthy in forum Technical - Questions
    Last Post: 6th February 2010, 12:33 AM
  3. 4age wiring Q's
    By Johnny_08 in forum Technical - Questions
    Last Post: 19th July 2008, 07:00 PM
  4. FS: Trev's AE71 Turbo Sedan
    By Trev084 in forum Cars for Sale (Toyota Only)
    Last Post: 1st July 2008, 08:12 PM
  5. Replies: 4
    Last Post: 29th March 2008, 10:30 PM
