I answered the exact same question only this week... read back a bit more.
The general answer in no. Unless you have both axles next to each other, do some measurements and find a way.
i was wondering if the standard T series axles with the thin bearing will fit the t series jdm disc brake housing that normally has the wide bearing?
i know the splines are the same, just not sure on the bearing location?
<div class='quotetop'>QUOTE (Jonny Rochester @ Aug 29 2008, 05:52 PM) </div>Cheers, ill get both axles tgether and check it out
