Results 1 to 10 of 18
Thread: Best 4a engine for turbo conversion
    Dan
    Wa
    Default Best 4a engine for turbo conversion
    Ok here goes.
    i am ready to do my engine conversion,
    i hav turbo and low mount manifold
    looking for the best all round 4A engine to turbo to put into my ae86
    engine will be freshened up and head will be rebuilt with bigger valve springs and ported port matched and polished.
    Q1:i have heard 16v big port the way to go if so what model,
    all help appreciated
    Veteran hachi_dk's Avatar
    Filip
    Jozzaville
    yer big port conrods are thicker, i know that much.
    so being thicker, im pretty sure that equals stronger.
    hope that helps
    Seamus
    Milton
    Best all round motor to turbo is the AE101 4AGZE
    Second best all around motor is the AE92 4AGZE
    I chose the AE101 over the AE92 because of the slightly higher compression. It has slightly thinner rods than the AE92 version, but this will never be a problem for 90% of people going turbo.
    Bigport 4AG, Smallport 4AG, and both 20V's are shithouse for boost in stock form. They'll handle 5-10psi but even then it's only a matter of time before the weak pistons/ring lands/rings die in the ass
  • #4
    Dan
    Wa
    cheers 70XIN
    im guessing the AE101 does not hav dizzy set up which is good.
  • #5
    Seamus
    Milton
    Yep has crank-angle-sensor and coils, way way way better
  • #6
    Dan
    Wa
    cheers heaps for the help
    is the ae101 4agze all bigport
  • #7
    todd
    they are all smallport.
    the only bigport 4agze was in aw11, and generally percieved as the worst of the bunch.
  • #8
    Junior Member bounceae86's Avatar
    ae92 has coils and angle sensor too, if you want to change compression sure all you need is a head gasket witch youl have yo do anyway, from wat ive read the ae92 is that little bit stronger but ul never use these engine to there blowing point,there bulletproof
  • #9
    Senior Member dave2221's Avatar
    if you were going to use a silvertop tho, if you went forged pistons and rings, would that be suitable for a t28bb? (mate pulled one off his s15 i might get)
    then run between 12 to 17psi
  • #10
    Davey & Riki-lee
    South Australia
    Seaford SA
    4agze have forged internals stock dont they?
    Our introduction - Click here
  • Page 1 of 2 1 2 LastLast
    1. w series conversion for your 4a engine
      Last Post: 29th March 2012, 09:51 AM
    2. 4a conversion for ke70
      By sailor in forum Cars or Parts Wanted
      Last Post: 27th March 2012, 10:10 PM
    3. w series to 4a conversion
      By No Offence in forum Cars or Parts Wanted
      Last Post: 4th September 2011, 07:36 PM
    4. w58 conversion for 4a
      Last Post: 28th May 2011, 08:28 PM
    5. mitsubishi cordia turbo to corolla engine conversion SYD
      By spoon in forum Car Parts For Sale
      Last Post: 15th July 2010, 07:56 AM
