how did you get code 5?
what was the flashing sequence
Hey people.
Apparently when my 4AGE ecu was hooked up to diagnostics it kept coming up with code "5" which is not a toyota diagnostic code........even after being reset....
Anyone know what this code is? My mechanic seems to think it is a modified ECU.......
any thoughts?
I'm also up for a new radiator.......ughhhhhh :fap:
My JDM HATCH - http://www.ae86drivingclub.com.au/forums/showthread.php?t=2677
Parts Wanted/For Sale - http://www.ae86drivingclub.com.au/fo...ead.php?t=3527
SOLD My GTI HATCH - http://www.ae86drivingclub.com.au/fo...546#post204546
- Blaise Pascal
<div class='quotetop'>QUOTE (ke70dave @ Sep 9 2008, 06:41 PM) </div>I have no idea, all I know is there used to be an apexi computer hooked up to my car and my mechanic said it looks to be a modified 4AGE ECU...
Just wondering if anyone knows anything about this.
Moved to the right section... a Technical question should be asked in the Technical Question area
4AGE is here! Cheers 44GTE and Anthony for your help! http://www.ae86drivingclub.com.au/fo...ad.php?t=10384
AE86 Driving Club Official Rules -please read!
What am I doing right now? Twitter me!
you sure it wasn't 32, or 23 lol
<div class='quotetop'>QUOTE (gunbz-r @ Sep 10 2008, 07:01 AM) </div>Absolutly Positive it was 5........If anyone knows and can tell that would be great. I honestly dont know anything about ECU's so I have no idea haha
did you see it flash? it would flash 5 times, but in what sequence, i seriously doubt, that if someone modified it, they would go to the extent of trying to modify the codes, and you can't retune factory toyota ecu's
I will just about bet my balls, that it is 23 or 32, either it flashed twice paused then flashed 3 times, or vice versa
Do you have a pic of this so called modified ecu, or atleast a part number
Hmmmm did some reasearch and found the below which is funny cos I had my O2 sensor replaced....Hasnt been working for a long time! :ermm:
Seem that it can be 5 or 21.....if my reseach serves correctly...
Thanks people!
5 / 21 OXYGEN SENSOR SIGNAL/OXYGEN SENSOR HEATER SIGNAL
OPEN OR SHORT IN OXYGEN SENSOR OR OXYGEN SENSOR SIGNAL
