no they dont, the 3sgte inectors are end feed unlke the side feed that the 20V wants, what you need are 1J injectors
As it states do the 3SGTE injectors fit into silvertop 20v quad throttles?
The injectors are 440cc.
Any info great :2thumbs:
3S-GTE injectors (SW20, ST185, ST205) are side feed and are a perfect upgrade for a 20valve if your running turbo. They are very similar to 1JZ-GTE injectors, which are also good to use. (1JZ-GE injectors are not side feed).
