Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: t18 gear- ke70
    Jul 2010
    hey all
    sorry to be a pain but i just picked up a t18 for the diff+tailshaft so i was wondering what else i can use from it bolt in to my ke70 i.e any of the suspention? gear box? or any thing i can use for 4age cinversion?? will be had a look through the tech articles but couldnt really find any thing
    jarrad
    ** can i get this moved to the technical questions please mods? sorry i was in a rush!
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    its been covered so many times before.
    struts/brakes/steering arms are a good upgrade for a ke70 becuase you can run the bigger shock diameter and alos have bigger brakes at the same time.
    cant really use anything else in a 4age conversion except from the second half of the tailshaft back.
    you could always do the (2t?) conversion into the 70
    FTP.
    go the 3tc conversion into the ke70....
    Senior Member sdm86's Avatar
    May 2010
    Scott
    Tas
    Devonport
    pedal box master cyl etc etc youll need a hydraulic clutch..
    also good to have a few gearboxes lying around
    either for your own use or for sale
    Ferny Grove
    gearbox
    full tailshaft
    diff
    you'll need a 4a bellhousing to make it work. it will accept 4a clutches, the output shaft spline count is different to 86/71 but you have the front tailshaft half so it works out
    pedal box doesn't line up with KE70 bulkhead bolt holes, you can make it work, i've used one, but it sat the column too low and off to the right. could cut and reweld it, depends how keen you are i guess
    keep the clutch master, slave and hard line as they are the same/similar as JDM 86
    keep the struts and coilover them, as mentioned earlier brakes are bigger than 70 but smaller than 86
    Veteran slydar's Avatar
    Dimitri
    obviously the series 1 bumpers sell for good money on here. and there are particular parts of the front paneling of 1 version that are compatible with the "jdm quads lights" set up.
    you definitely want the gearbox x member too. as often youll get a 86 t50, but the 86 x member wont work.
    if youre really keen maybe take the key barrels if theyre a matching set.
    maybe the carpet will work?
    tail lights.
    78's
    Jul 2010
    cheers guys great info!
    i picked it up today so i will see what i can salvage :greenbounce:
    Aaron
    In the Mountains
    centre console and steering colum is also the same as ke70. and the mirrors if its a later model...
    Calvin
    Kilsyth
    if its a series two and you have a road worth condition right hand tail light i will definitely take it. series two meaing plastic bumpers and swaybar on the diff
    T18 in the build
    Jul 2010
    <div class='quotetop'>QUOTE (Hokey @ Sep 13 2008, 07:23 PM) </div>
    sorry mate its a series one
  1. Replies: 1
    Last Post: 11th March 2012, 09:08 PM
  2. WTB: KE70 centre console with gear boot and gear knob
    By jaqule in forum Cars or Parts Wanted
    Last Post: 2nd December 2011, 04:10 PM
  3. T18 Diff Gear Ratios
    By the_van_can in forum Technical - Questions
    Last Post: 17th January 2011, 10:01 PM
  4. T18 running gear into a ke70?
    By Hazzard in forum General Topics (No Technical Questions)
    Last Post: 9th June 2010, 02:22 AM
  5. T18 gear lever surround and boot.
    By floody31 in forum Cars or Parts Wanted
    Last Post: 1st August 2008, 07:23 PM
