Results 1 to 7 of 7
Thread: 4agze crank pulley removal
    Junior Member bounceae86's Avatar
    Default 4agze crank pulley removal
    anybody have any wild ideas how to get the crank pulley of my 4agze? bolt is off but the pulley is just stuck on the keyway or something?? if i tap it with a hammer either side you can feels it shifting but it just dosnt want to come forward
    todd
    buy a gear puller from your local tools store and it will do the job without damaging the keyway etc.
    Calvin
    Kilsyth
    doesn't it have bolt holes on the pulley so you can make your own puller using some flat steel?
    T18 in the build
  • #4
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    then wait till u get to the cam belt crank pulley.... uoooooh!!!
    AE86 THE BEST
  • #5
    stefan
    vic
    eastern suburbs
    dont waste your money on a gear puller.
    awsome old school trick i learned, turn the motor to tdc then turn it over a tiny bit more, pull out spark plug number 1m grab some twine or thin rope and feed in as much as the cylinder will take. turn the motor back to around tdc and it wont move any more
    undo the bolt with the largest breaker bar you can make/find
  • #6
    Quote Originally Posted by yoshimitsu9 View Post
    i have the bolt off its the pully wont come off now,i used a rachcet on the flywheel bolts to stop the engine rotating..but its a 2 man job
  • #7
    Veteran Nikkojoe's Avatar
    Tom
    You can buy harmonic balancer remover tools. They are a universal fit and use a pretty standard thread. Even a steering wheel remover tool works
  • Similar Threads
    1. High Boost Alloy Crank Pulley - 4Agze
      By LittleRedSpirit in forum Car Parts For Sale
      Last Post: 16th August 2011, 12:27 PM
    2. 4agze 165-175mm crank pulley
      By Nikkojoe in forum Cars or Parts Wanted
      Last Post: 3rd February 2010, 12:45 PM
    3. WTB: 4agze standard crank pulley
      By mookschank in forum Cars or Parts Wanted
      Last Post: 9th July 2009, 11:08 AM
    4. 4agze- what else do i need to install a oversize crank pulley
      By nvy-412 in forum Technical - Questions
      Last Post: 23rd July 2008, 09:35 PM
    5. 4agze / 4ag crank pulley's
      By RyGuy86 in forum Technical - Questions
      Last Post: 20th August 2007, 01:16 PM
