Results 1 to 10 of 13
Thread: CUSCO Strutbrace $100 AE86
    Default not fer sale
    Dw :p
    <img src=http://img114.imageshack.us/img114/3193/p1020339jk4.jpg border=0 alt= />
    Anyone get the License plate of that B& Hammer?
    Ferny Grove
    double check dude, this should fit a 70 no worries
    what exactly doesn't fit??
    Veteran svenmate's Avatar
    Svenbot
    East
    only adjustable ones fit ke70 apparently
    cheap
    AE71 Build Thread
    性交を愛する
    +1 on gilly.
    I had the same one. Fitted fine, Make sure it's around the correct way
    Junior Member magee_71's Avatar
    hey mate, you should try what gilly has said & double check & same with marvis. I've got an ae86 front strut brace on my ae71 that also fits on my girlfriends ke70. Try one on each side, if the holes don't line up then swap the sides around.
    Hope it works out for you mate & you don't sell something you wanted in the first place.
    cheers tom
    Ferny Grove
    this one is adjustable, the linkage bar is threaded, should be able to bolt one end on the to the tower and spin the rod until the other side lines up.
    the non adjustable ones don't fit 70's in my experience but this is not that style so i'm curious as to why it isn't working out
    I will give it a shot again, seems the bolt spacing is way off
    I thought it would fit as 86 struts fit in a KE70, i assumed it would fit.. then again i dunno if you use KE70 top hats in a 86 struts conversion?
    Svenmate, You meaning im selling it too cheap? im not sure what they are worth. what the retail for?
    性交を愛する
    Upside down! Upside down!
    Is the bar supposed to be towards front or rear?
    it fits
    Not fer sale anymore
  1. Adjustable strutbrace for xe7x
    By kyle unwin in forum Car Parts For Sale
    Last Post: 1st July 2011, 02:53 PM
  2. Replies: 3
    Last Post: 26th January 2011, 06:35 PM
  3. cusco rear tower brace $100
    By green_boy_91 in forum Car Parts For Sale
    Last Post: 23rd March 2009, 07:18 PM
