Results 1 to 10 of 20
Thread: F-Series Tarago Diff Models and Years?
    Default F-Series Tarago Diff Models and Years?
    Hey guys i have found a toyota tarago diff (manual) i want to use in my sprinter, its from a 1984 tarago.
    Do you have to use a tarago diff from a yr21 or yr22? or is yr20 ok aswell, being from an 1984 tarago i have a feeling it may be a yr20 im not sure would i be able to use this diff and will it be an f-series?
    Veteran Dom86's Avatar
    Dom
    Balga
    yr22. 85-89 I'm pretty sure.
    This may be of use to you...
    http://ourworld.compuserve.com/homep...tepho/diff.htm
    The Track Car Build: Indigo
    A Heap Of For Sale: The Heap
    Mt Macedon
    AFAIK YR20 and 21 ran E series, and it was only the YR22 that came with an F.
    Personally I've played with a YR22 which had an F series according to both the build plate and my eye when I pulled the thing out. Never played with a YR20 or YR21.
  • #4
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
  • #5
    Veteran Nikkojoe's Avatar
    Tom
    ahh good to see norbie's axle page working again
  • #6
    Jonathan
    Quote Originally Posted by lloydious86 View Post
    Well, if you are taking the diff out of the car, then YOU can look at the ID place and tell us what diff it is. As Hen said, probably E series. I could look it up, but only you can be sure because YOU are the one with the ID plate.
    It probably isn't LSD, and isn't a straight bolt in.
  • #7
    Gone
    Joel
    Picton
    Im pretty sure F series sat behind the EFI engines.. E series were with carbed engines
  • #8
    Seamus
    Milton
    YR21 and YR22's both have F-series diffs
    I have pulled one out of both
  • #9
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    yr22 had e series in the carby model and the f series came behind the efi model
    if its already out of the car rip the centre out and measure crown wheel
    f series are 7.5 inch and e series i think are 7.1??
    MY JZX83 (clicky)
  • #10
    ok guys thanx heaps for the info tried searching but fail you guys are the shit ta, the diff is getting delivered 2moro if its an e-series or f im not fussed either way because the t18 lasted me a long time and im only making 240hp so if its an e-series its only .4" smaller 1mm smaller in axle width aswell to the f-series so the e-series will still be a good upgrade and cheap also
    t18 6.7"
    e-series 7.1"
    f-series 7.5"
    YR20 Solid Axle (leaf) E292: 7.1", 4.10:1, 2 pinions, Open
    4x114.3 1415mm Drum
    YR21 Solid Axle (leaf) E282: 7.1", 4.30:1, 2 pinions, Open
    4x114.3 1415mm Drum
    YR22 Solid Axle (leaf) F282: 7.5", 4.30:1, 2 pinions, Open
    4x114.3 1445mm Drum
  • Page 1 of 2 1 2 LastLast
    1. does anyone know the diffrence in the ae86 models and years
      By enzo in forum General Topics (No Technical Questions)
      Last Post: 2nd May 2012, 02:05 AM
    2. F series DIFF out of a Tarago EFI van
      By sumfancyname in forum Car Parts For Sale
      Last Post: 26th April 2011, 10:47 AM
    3. Tarago Diff- F Series 4.3 ratio
      By Cerby86 in forum Car Parts For Sale
      Last Post: 12th November 2010, 04:27 PM
    4. Wat LSD goes into a F series Tarago diff?
      By Dongaz in forum Technical - Questions
      Last Post: 1st July 2009, 10:43 AM
    5. What is a YR22 Tarago F-Series Diff worth?
      By Golberg in forum General Topics (No Technical Questions)
      Last Post: 27th May 2009, 11:46 AM
