Results 1 to 6 of 6
Thread: gremlins in wiring
    Senior Member Mr Awsome's Avatar
    Dave
    Plympton
    Default gremlins in wiring
    It's a 86 running a 4ac.
    Some symptoms were...Dash blew up (rev gauge wasn't working, dash lights didn't work, mystery blue smoke and burning plastic smell), battery was getting drained (alternator is wired correctly), wipers wouldn't turn off, clock got cracked(yes it actually cracked).
    any ideas of what i need ot be looking for?
    Mt Macedon
    You're electrics are fucked. It sounds fairly major, so do the normal things like check battery voltage when the car's off and when it's running and check the fluid level in the battery. Then if that's all ok start slowly going through it with a multimeter and see if/where you're getting funny stuff going on.
    Jonathan
    You replaced some random fuses with alloy plate, you wired up the radio yourself, then you ripped the radio out leaving the live wire to hang.
  • #4
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    I suggest you remove your dash, pull all the wiring out and inspect.
    Then find yourself another sprinter harness and put that in.
  • #5
    Dave
    Plympton
    Quote Originally Posted by Jonny Rochester View Post
    nope fuses are fuses no plates. yes theres a head unit but it was done properly. there are no live wires hanging. all wires were solded and shrink wraped.
    Quote Originally Posted by Golberg View Post
    i got the dash all riped out but putting in a new harness sounds way to complecated.
  • #6
    Elite rthy's Avatar
    Leo
    Tulla
    lol thats how i bought my ae71, the wonders of frankston
  • Similar Threads
    1. Replies: 10
      Last Post: 22nd December 2012, 03:21 AM
    2. 4age smallport electrical gremlins
      By wanted_ae86 in forum Technical - Questions
      Last Post: 17th September 2012, 05:36 PM
    3. electrical gremlins
      By Tim.duncan in forum Technical - Questions
      Last Post: 18th October 2011, 12:35 AM
    4. Help with wiring...
      By KameSama in forum Technical - Questions
      Last Post: 9th July 2008, 12:10 PM
    5. Replies: 4
      Last Post: 29th March 2008, 10:30 PM
