yes it can be done, search
just wondering, i have a smallport FWD 4age that i want to put into a ke70. Can it be done? Or do I need to source a RWD one, i know the cooling system has issues that will need to be sorted, but aside from small bits and pieces, is it possible?
Cheers,
YAZE
no such thing s a RWD smallport engine.
pretty easy to covert to rwd tho.
youll need all the normal parts for a ke70 to 4age conversion.
and then all youll have to do is do something about the intake manifold, and the thermostat situation.
its pretty simple really, either buy a jdm rwd intake manifold (heaps of the sponsors have them in stock) and an adaptor (big port to small port, pretty sure kaizen has one in stock) for the neatest set up. or just take the manifold to a fabricator, and have them swap the throttle body end for end.
the water situation is much the same, you can either get all the jdm ae86 rwd water pump/neck/alternator bracket gear (expensive) or just hook the remote thermostat up in the same order as it is in the ae92sx, but position it beside the engine, to suit rwd with some random hoses from supercheap/wreckers.
78's
dont forget about the loom work
hardest part is to get it running =] out of all things
<div class='quotetop'>QUOTE (4AC power @ Sep 27 2008, 03:50 PM) </div>
pffff! loom is piss
smallport swap is simple and shouldnt present too many headeaches.
good luck with ur swap !
<div class='quotetop'>QUOTE </div>WHAT! haha you remember the problems me and slide had and you say this! it should be pffff looms are USALLY piss haha
Make sure U have everything,everything you need before commencing the swap..
search is your friend
cheers guys, i have begun collecting all the relevant parts, wish me luck! haha
