Results 1 to 6 of 6
Thread: CAMS
    Oldschool Member
    May 2008
    I'm looking into getting some cams for my bigport but don't want to get an aftermarket ecu.
    what are the biggest pair i can get to run on my stock ecu?
    Oldschool Member
    Sep 2008
    with an MAP 4age i am unsure of the limit, but think its 264 ??
    with a piggyback ecu such as an SAFC II my friend was able to run 272s pretty well.
    i have heard the AFM 4ages are able to handle slightly bigger cams on a stock ECU, although it could be a myth.
    edit.. my statement only takes into account Duration, and not Lift.
    Nathan
    Lilydale
    Distant00 on here is running, i think he said 278's on a smallport with stock ecu, seems fine, idling struggles more than usual when cold though.
    Sep 2010
    read:
    http://www.billzilla.org/4agmods.htm
    should answer your question
    enjoy
    Louis
    Auburn
    A mate runs a stage 3 kit in his smallport..not sure of the duration but pretty sure its around 278....its goes well...but it struggles at idle and low revs....his ecu is stock.
    A good computer would net alot of gains though...so maybe save some more doe and get it all done....
    also depends on lift and the shape of the cam lobes ....
  1. Colt Cams Tri-Flow Cams for the 4AG
    By dr.occa in forum Car Parts For Sale
    Last Post: 23rd August 2008, 06:54 PM
  2. Tighe Cams - 290 & 300 deg cams NEW! $600 very cheap!!!
    By johnO2 in forum Car Parts For Sale
    Last Post: 13th May 2007, 02:45 PM
  3. cams
    By dustyae86 in forum Technical - Questions
    Last Post: 16th November 2006, 11:22 AM
  4. cams
    By deanoo in forum Technical - Questions
    Last Post: 16th August 2006, 11:21 AM
