Results 1 to 3 of 3
Thread: Apexi PowerFC
    Senior Member Stain's Avatar
    Derek
    Far North
    Default Apexi PowerFC
    Has anyone used one of these on their 4AGE?
    I know alot of the Nissan boys use em and theres some nice bum dyno tuning software for em (so you dont even need to use the hand controller).
    But all their engines have CAS, not Dissys and have a O2 sensor (which my car doesnt...)
    So I was wondering how well it would work under those situations?
    Would it be possible for the PowerFC to work with a GZE CAS and Coilpacks?
    There's prob alot of better options, but I like the fact they plug into the existing 4AGE loom and have such good tuning software.
    Anthony
    AFAIK, the only pfc close to working on a 4AGE is actually a 3SGE MR2 version with a subharness to change back to bigport wiring. Im pretty suire this means it would be single ignition channel only. SO the CAS would be fine (24/1/1 just like the 3SGE) but the coilpacks not so much.
    Mark
    i don't believe their tuning software is any better than most other ecus.
    Take adaptronic for example. When i got my ecu tuned the guy did it with a laptop, no hand controller. I just got a basic tps tune and im running (but not using ) a narrow band 02 sensor and the standard MAP sensor.
    I am running quads hence the tps tune but im told that if your running a single throttle body and have a wide band o2 sensor you can get a quite good tune just using the adaptive modes if you are a bit patient and persistent, though it would be very hard to tune the top end of the rev range this way on the road!
    Most of the main wide band sensors plug directly into the new version adaptronic so the ecu takes the reading straight from there.
    Also the adaptronic runs with all standard toyota sensors so you don't need to change them and is just as easily run on a CAS setup as well.
    When i was putting mine in I talked the adaptronic fellas about making a direct plug in loom adaptor for the 4age but they reckoned the swap isn't common enough
    Though i do see the point that there are so many 4age variants that trying to supply a plug and play loom would just be a pain and when i saw how much stuff got cut out of my standard loom when i got it remade for the adaptronic i was glad i did it!!
  • Similar Threads
    1. sr20det engine, gearbox, exedy clutch, apexi powerFC etc etc
      By Brendo in forum Car Parts For Sale
      Last Post: 21st March 2011, 05:40 PM
    2. Apexi PowerFC 4A-GE
      By _bk_ in forum Cars or Parts Wanted
      Last Post: 29th November 2010, 11:07 AM
    3. 3S PowerFC + hand controller + stock ECU, SR20DET engine
      By dodgybrooks in forum Car Parts For Sale
      Last Post: 19th October 2009, 10:42 PM
    4. APEXI RSM
      By samuek in forum Technical - Questions
      Last Post: 7th April 2008, 01:41 AM
    5. Apexi avcr
      By eddie6943 in forum Technical - Questions
      Last Post: 5th December 2007, 03:18 PM
