Results 1 to 10 of 11
Thread: where to get rotors machined & brakes bled?
    Senior Member genkin's Avatar
    Jesse
    Default where to get rotors machined & brakes bled?
    where in SA? prefer southern suburbs or close to city
    gay
    seoul
    sinchon
    south korea
    also, what is a good price for brake bleed ?
    thanks guys
    yo. i got fans across the country. Dongsoo Kim is who they feelin' , last time you had a fan, it was spinnin' from tha ceiling ! haha.
    Quote Originally Posted by rollin33 View Post
    Sun_moon that?s badass name. you?re a loser go watch the sunset with your boyfriend.
    Senior Member Mr Awsome's Avatar
    Dave
    Plympton
    SA brake & clutch 118 Sturt St,
  • #4
    Dave
    Plympton
    its in the city
  • #5
    Site Supporter Javal's Avatar
    Josho
    Quote Originally Posted by AJPS View Post
    all clutch and brake st marys
    This.
  • #6
    Joel
    Blackwood
    Get a mate + 10mm ring spanner and bleed your brakes yourself:
    1. Get mate to press the brake pedal a few times then hold it flat.
    2. Open bleed valve on one brake (using 10mm ring spanner), let any air and fluid come out,
    3. Tighten bleed valve (whilst your mate's foot is flat on the brake pedal). T
    4. Get mate to pump the brake pedal a few more times then hold down.
    5. Repeat steps 1-4 until only nice clean fluid comes out (no air bubbles)
    6. Do steps 1-5 for all four brakes if necessary for a complete bleed
    Make sure in this process that you have ample fluid in the reserviour, otherwise you will get more air into the brake lines.
    For the fronts, often you don't even need a mate to pump the pedal. Simply open the bleed valve until only fluid comes out. The weight of the fluid above the brakes will push any air out in the lines.
    Process is the same for a hydraulic clutch.
    +1 All crutch and bake for machining
    AE86 4AGE "Slowly but surely"
  • #7
    Josho
    Quote Originally Posted by Joel-AE86 View Post
    Always do all 4, doing just one is silly.
    The pumping method is good, but flushing your brake fluid through is a good idea. If your fluid is rooted (has too much water content) then you'll have a good pedal if you do the pump and release - until it boils. Flush it through (~10 pumps / corner with bleed valve open), close it, THEN do the pump it up and release.
    Also when bleeding brakes, on 90% of cars, you bleed the caliper / cylinder furthest away from the brake master first and work your way towards it. LHR, RHR, LHF, RHF.
  • #8
    Joel
    Blackwood
    Quote Originally Posted by Javal View Post
    Only if you have made some changes to all the brakes. If you change your pads on the fronts there is very very little chance you will get air into your rear lines.
    It is good preventative maintenance to flush all your brake fluid every 12 months. Brake fluid degrades over time in use due to shearing and heat and you also get contaminents that build up over time that degrades pistions.
    Often a good flush on an old car can really improve the pedal feel and braking response.
  • #9
    Veteran MINIHORSE's Avatar
    Felix
    Inglewood
    Quote Originally Posted by Mr Awsome View Post
    DO NOT GO TO THESE GUYS
    Possibly the worst people ive ever had to deal with, they serviced the brakes on my Peugeot 205 GTi, for its regency clearance, went to regency, the car didnt pass due to brake biass, went back and explained to them so they fitted 4 new rotors and pads, without my permission, then claimed they are working perfectly, took the car back to regency and they failed again, went back 3rd time, and complained the guy started swearing at me in front of dad saying i should never have brought this piece of shit into his workshop, and that peugeots are a waste of his valuable time (i am also awear of this lol) and as i drove off he kicked a dent in my 1/4 panel,
    his insurance premium should be a little higher than usual now
    Pm Cracker/Slippry/Dan the Man, he works at a brake joint on the parade, just tell him who you are, im sure he would be happy to help you out
  • #10
    dan
    adelaide
    adelaide
    yes come to power brakes
    206 the parade norwood sa 5067
    its a vintage company lol
    it been on the parade for over 50 years
  • Page 1 of 2 1 2 LastLast
    1. jdm rotors + brakes .. front and rear
      By redsprinter in forum Cars or Parts Wanted
      Last Post: 14th July 2010, 11:43 PM
    2. S13 Front Hubs, rotors + brakes.
      By All Drift Modifications in forum Car Parts For Sale
      Last Post: 11th April 2009, 12:52 AM
    3. s13 brakes and rotors, other ae86 parts
      By samuel in forum Car Parts For Sale
      Last Post: 5th February 2009, 10:00 PM
    4. Front Brakes: Rotors and Pads for ae86
      By li21 in forum Cars or Parts Wanted
      Last Post: 3rd January 2008, 11:50 PM
