Results 1 to 7 of 7
Thread: 20v 4age vct solenoid blank off
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    Default 20v 4age vct solenoid blank off
    hey all just looking for some pics or ideas on how to blank off the old vct solenoid does any company out there make it or do you have to make it is there something i have to look out for when making a plug?
    mat
    the dyno pull to 300rwkw
    Moderator Sam-Q's Avatar
    Endeavour Hills
    there isn't a port into the side of the head, it's purely bolted there out of convenience. Put the thing off and plug the hoses
    Mathew
    Sutho Shire
    hold on what are you talking about im talking about the solenoid at the front of the motor near where the dizzy is on a 16v head there is a small solenoid that controls the vct on the 20v
    Steve
    You mean the VTI solenoid??
    Endeavour Hills
    ah a VVT solenoid cancelling plug, I should make those
    Mathew
    Sutho Shire
    vti doesn't make any sense
    and yeah that one im not sure if there is anything to look out for i only breifley looked at it but ill have another look soon as i know there is about 3 oil galleries leading in there and if just covered over say good by to the cam shafts so i was just thinking if you can just put a cut down alloy bar in there i was just going to turn down some with .001 interference and some locktight and insert then make a little bracket to hold it all together but the only thing i was worried about was that maby 2 oil galleries have to meet somewhere
    mat
    Endeavour Hills
    no the whole point is so they don't meet, one channel is from the main supply of the head and the other goes to the VVT solenoid. I would just use the original O rings size over making it a non removable inteference fit.
  1. WTB: AE111 20v BT VVT/INLET CAM GEAR & VVT SOLENOID.
    By Gunner in forum Cars or Parts Wanted
    Last Post: 24th July 2012, 08:25 AM
  2. TVIS Control solenoid to suit a 4age 16v
    By dirk in forum Cars or Parts Wanted
    Last Post: 12th September 2009, 04:47 PM
  3. 20v 4age rwd water kit/rear blank off plate
    By markiitourerv in forum Cars or Parts Wanted
    Last Post: 25th February 2009, 07:46 PM
  4. Blank Canvas
    By Eircamae86 in forum General Topics (No Technical Questions)
    Last Post: 18th January 2009, 08:50 PM
  5. Silvertop 20v vvt solenoid switch
    By shelldrake in forum Cars or Parts Wanted
    Last Post: 23rd May 2008, 05:08 PM
