Results 1 to 3 of 3
Thread: Will ae71 swaybars fit in a te72
    c
    Default Will ae71 swaybars fit in a te72
    As per title, will the front swaybar from a ae71 fit in a te72?
    Veteran shift_rook's Avatar
    SE Burbs
    why not have a crack?? it's only like a 10 minute job, would be quicker findin out yaself than gettin an answer on here
    Veteran Konakid's Avatar
    Henry
    Eastern
    Ten minute job?
    Not unless you have drop out swaybar mounts ala Cusco setup.
    Would take a good half hour, should fit tho.
  • Similar Threads
    1. WTB:LSD, AE71 Pedal box,work equip 01,brake upgrade,swaybars
      By psone in forum Cars or Parts Wanted
      Last Post: 21st January 2012, 04:56 PM
    2. te72 diff, will it fit?
      By cr86zy boy in forum Technical - Questions
      Last Post: 6th August 2007, 09:52 PM
