Do the basics:
- Check if there is spark
- Check timing with a timing light
- Check power and earth to injectors, coil, ignitor, ECU, etc, etc
Hopefully it's just something silly you forgot to hook up.
But it could also be the Microtech setup. Are you sure all settings are correct?
