Results 1 to 8 of 8
Thread: 4age oil filter
    Default 4age oil filter
    hey guys/gals
    need to get a oil filter for a jdm 4age 16v blue top
    is it a Z158 ?
    is it the same as a 4ac filter?
    if not can someone please tell me the right code to get
    thanks
    Colin
    Senior Member ae86=fun's Avatar
    Tobias
    Battery Point
    i use ryco filter Z386 on my bluetop.
    Ryan
    qld
    brisbane
    Aust.
    nope, 4ac one is larger then a 4age one.
    search for ae82 twincam 4A-GE in their books and i think you get the same code as above ^.
    Dave
    New South Wales
    Don't know if this is relevant however some filters I believe the proper ones/good ones have a safety valve inside the filter. My old one had it it was a Valvoline filter but can't remember the number on it. The valve is supposed to open if the filter gets clogged so the engine doesn't starve for oil. The new one I put in didn't have it however I change my oil more frequently so this shouldn't be a problem.
    Anthony
    Quote Originally Posted by SXC-086 View Post
    indeed its called a anti-drain back valve... you better make sure they have one... only some of the ryco's have them, if yours doesnt change brands
    Davey & Riki-lee
    South Australia
    Seaford SA
    Toyota gen - E1 short filter or E2 long filter to clear your exhausts n what not
    Senior Member hilux05's Avatar
    Rich
    Sunshine Coast
    valvoline V07 or Z386..
    "you know what i mean"
    Oldschool Member
    Mar 2005
    Roy
    Bris
    I used to use a Z158 for the larger size, but when I fitted my sandwich plate it fowled on my exctrators, so went back to using a Z386.
    Edit: I'm running a JDM bigport 4a.
  1. 4age Oil filter Mount
    By keimeier in forum Technical - Questions
    Last Post: 24th March 2010, 11:41 PM
  2. what size is fitting for 4age oil filter
    By cracker in forum Technical - Questions
    Last Post: 25th December 2009, 07:29 PM
  3. 4AGE Oil Filter Relocator
    By 45LDN in forum Car Parts For Sale
    Last Post: 1st June 2008, 08:58 PM
  4. 16v 4AGE oil filter
    By dems in forum Technical - Questions
    Last Post: 1st March 2006, 04:27 PM
