Results 1 to 6 of 6
Thread: air filter foam
    Aug 2010
    Sutho Shire
    Default air filter foam
    When running a foam filter on quads,what would happen if one filter were to break and bits of the foam
    were sucked into motor?would it just burn up and nothing to worry about?has this happened to you?
    what was the outcome?thanks for any help
    Veteran 70rolla's Avatar
    May 2010
    Tyler
    Sutherland Shire
    filter oil helps
    Steve
    Mostly your theory is correct.
    Not something i would try thou.
    Too many unknowns, could effect the air fuel entering properly amongst other things.
    Left overs if they escaped the exhaust valve would next get caught in the catalytic convertor.
    Definitely something you want to avoid.
    Your question suggests its already happened??
    Aug 2010
    Sutho Shire
    nah hasnt happend,just randomly started thinking about this
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    another good reason not to run a CAT :|
    =D
    Aug 2010
    Sutho Shire
    i dont run a cat,today i purchased a new filter element which is much thicker and stronger,lifes good
  1. Changing the Air filter
    By x744 in forum Technical - Questions
    Last Post: 23rd June 2012, 11:44 AM
  2. (vic) air filter/ air box for ae86 w 4age needed asap
    By dove grey 64 in forum Cars or Parts Wanted
    Last Post: 11th October 2011, 07:29 PM
  3. getting air filter legal (ADM with 4age)
    By Leigh in forum Technical - Questions
    Last Post: 22nd May 2009, 10:18 AM
  4. Air filter setups for quads
    By julzy in forum Technical - Questions
    Last Post: 26th December 2008, 11:01 AM
  5. Air filter and Panel box
    By poh_86 in forum Technical - Questions
    Last Post: 11th December 2005, 01:35 PM
