Results 1 to 4 of 4
Thread: 4age MAP sensor/KE70 accel cable/solid front brake lines
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    Default 4age MAP sensor/KE70 accel cable/solid front brake lines
    3 things I require at present...
    - 4age MAP sensor in good working order
    - KE70 accelerator cable (for 20v conversion
    - The solid brake lines in the front of the ae86, aka from the master to where they join to the flex lines in the guards... must be in good condition, no threaded bungs etc
    all in Brisbane if possible.
    Niz
    BENT MECHANIX - Garage 20:
    Niz
    South~Slide Briz
    MAP sensor sorted..
    Clint
    I have a accel cable, PM sent.
  • #4
    Niz
    South~Slide Briz
    cable sorted...
  • Similar Threads
    1. WTB 4age 16v map sensor connector and t18 front struts
      By kronix in forum Cars or Parts Wanted
      Last Post: 18th June 2010, 08:39 PM
    2. AE Hard/Solid 'front' brake lines
      By NIZLAH in forum Cars or Parts Wanted
      Last Post: 2nd July 2009, 08:39 AM
    3. 4agze Accel cable mount, 4agze ae101 air intake temp sensor
      By Roo. in forum Cars or Parts Wanted
      Last Post: 13th May 2009, 07:00 PM
    4. KE70 front brake lines
      By Simon-KE70 in forum Cars or Parts Wanted
      Last Post: 11th January 2009, 12:11 PM
