Results 1 to 8 of 8
Thread: Need help with my set up
    Pun
    Bkk
    Bkk
    Thailand
    Default Need help with my set up
    Hi
    I am having a problem about my suspension setup
    My Problems:
    1) My car rear end is about 1"-2" lower than Front End, so it looks really stupid.
    2) I couldnt lower the front end much lower, because Fr tyres hit inner guard when I turn during my car bounce.
    This is my set-up:
    195/55/R15 on 15"x7" +10 offset wheel
    Tokico Hts
    TRD Springs F 6kg R 4.5kg
    No coil-over
    What I did was:
    1) Put all in, but i didnt use coil-over strut casing, because I didnt want to abandon my Front 6Kg springs.
    2) Caster & Camber are adjusted for a fine clearance, but the front still hit
    Now, what should i do?
    Get coil-over kits & lower the front end to match the rear end?
    Will I need to get a new coil spring for it??
    Any suggestion guys?
    Mt Macedon
    If you mean your front tyres hit the plastic inner guard, then just pull it out.
    However you have no adjustment for your ride height with your current setup. You'll have to either get higher rear springs or lower front springs to even things out.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    there is also a steel lip on the inside gaurd facing towards the front of the car that can be bashed down for more room. Where is it rubbing exactly?
  • #4
    Pun
    Bkk
    Bkk
    Thailand
    the first contact would be an inner plastic like Hen said, but I not sure if it actually hit side fender (metal part).
    I'll try to pull the plastic off first & check out that steel lip.
    Are Fr & Rr TRD springs match ride height equally? or we really need to used coil-over adjustment to match it? I thought they are suppose to be...
    Thanks Hen & SamQ
  • #5
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Your tyre profile is a bit thick too for a sprinter.
    You'd be better off with a 195/50/R15.
  • #6
    Endeavour Hills
    you might also be having the gaurd rub where the gaurd meets the bumper. This is why most sprinters have a cable tie there; its so they can get rid of that metal and plastic lip with the screw through the middle.
  • #7
    Pun
    Bkk
    Bkk
    Thailand
    Oh!! thats another easy way, isnt it....
    Cheers guys
  • #8
    性交を愛する marvis's Avatar
    Let us know how it goes!
    marvis.
    Quote Originally Posted by trikzlane View Post
    I love streeting, Lowdown cars and watching the world unwind by every word Marv types.
    Quote Originally Posted by keiichi View Post
    dont you get raped by the police everywhere you go?
  • Similar Threads
    1. WTB 14 x7 with a 15 p off set and set of 4
      By Celica RA45 in forum Cars or Parts Wanted
      Last Post: 4th March 2012, 07:48 PM
    2. Replies: 2
      Last Post: 13th November 2011, 04:38 PM
    3. Set Of 14X7 Deltas & Set Of 14X6 Cheviot Mags
      By noccy in forum Car Parts For Sale
      Last Post: 6th February 2011, 07:42 PM
    4. Replies: 18
      Last Post: 1st January 2010, 11:15 PM
    5. Replies: 17
      Last Post: 23rd May 2009, 01:27 PM
