Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: 4k Battery/Alternator problems
    Senior Member ke70 xx's Avatar
    Troy
    Woody
    Default 4k Battery/Alternator problems
    Not sure if im posting in the right spot but my battery in my car keeps dieing even thought the battery and alternator have been replaced very recently due to this problem. There is one wire coming off the alternator that i think is an earth but cant see anywere for it to go. I have had a look at my mates corolla to try and see and i couldnt even see this wire on his. If anyone can help me it is greatly appreciated. Cheers Troy
    Quote Originally Posted by MINIHORSE View Post
    "if i ever get another 86 i think it will be a track only car"
    Tried that....failed.....you will too....its like sleeping next to a supermodel everynight and only getting to nail her 5 times a year
    Veteran biggo's Avatar
    Nick
    Noosa
    take a picture
    there should be a big fat 3-4mm wire coming off the alternator. This goes to batt B+
    Assuming thats done, start her up and get a multi meter on there. It should read higher than 12.6 more like 13-14volts
    Troy
    Woody
    This is the best photo i could get. Let me know what this wire does because my battery keeps dieing and i go back to work on the 5th.
    Nick
    Noosa
    not 100% but i think there is a terminal on the back of the alt that gets some b+ power.
    did you get a multi meter?
    Troy
    Woody
    Ill go have a look now but what am i ment to put the multimeter on? I dont even know how to use them. And whats B+? I dont know stuff all about this kinda stuff.
    Nick
    Noosa
    B+ is battery positive
    Put multi meter on battery get a reading. Then start it up and put battery on the alternator, you only need to put the red stick on the terminal with the big fat wire on it. groud black to chassis.
    While its running whack the multi meter on the battery again and see if its changed.
    Troy
    Woody
    I dont know how to use a multimeter.
    Senior Member Beck's Avatar
    Andrew
    I'm pretty sure they come with instructions.
    Troy
    Woody
    Im pretty sure im not an electrician. Its my dads old school one so doesnt have instructions. Dont say nething if ur not gunna help.
    Andrew
    http://www.google.com.au/search?sour...e+a+multimeter
    I was actually trying to be helpful. My point was that it's really not at all difficult to find out how to use a multimeter. Oh, and you don't have to be an electrician to use one.
    Good luck with it.
  1. 4k - problems oil related
    By anastasios in forum Technical - Questions
    Last Post: 7th August 2009, 01:08 PM
  2. ke70 4k alternator.
    By Marco in forum Cars or Parts Wanted
    Last Post: 20th March 2009, 01:38 PM
  3. 4K Alternator
    By Andrew in forum Cars or Parts Wanted
    Last Post: 29th October 2007, 07:44 PM
  4. 4agze alternator dead or is battery too big to keep charge ?
    By kravit in forum Technical - Questions
    Last Post: 24th July 2007, 07:41 PM
