no ecu needed, need to modify the distributor i believe. couple of other things you need to do, have you tried searching?
thinkin about doin carbies on a 4age or even possibly a 7age. What do you Recommend im thinkin 45mm webers? also do you still need a ecu?
yeah man i had a bit of a skwizz couldnt find much
have no read it in full, but i think the info you need should be here
cheers man
Just warning you, that there is no legal way of doing this and having it streetable.
yea, think your right there is some emmissions laws i think
Yeah, the car wont pass emissions requirements with carbies. The car must maintain all factory emissions equipment from the car which the engine came out of. This includes the EFI system.
But as with anything, if you know the right people you can get anything passed. Doesn't make it legal though.
yeah might try get away with it for a little while
y would you put carbys on it?
