Results 1 to 10 of 16
Thread: My 4AGE Setup - Pros & Cons - Advice please!
    Dan
    Vic
    Western Subs
    Default My 4AGE Setup - Pros & Cons - Advice please!
    Hi all,
    So i pulled my finger out and have decided to 4AGE my KE70 now i have been getting parts for quite sometime now and am at the stage where i ahve to put it together now im just wanting some advice and pros and cons of my selected setup where i can go better whats holding me back etc..
    It should be Noted that i dont have barrels o cash sitting around but this is the best for what i can afford so this is what i'll lets and we'll go from there.
    Engine Management:
    - Std 4AGE Bigport ECU
    - Emanage Blue With 4AGE Harness
    Engine:
    The bottom end will be completly balanced also.
    - Bigport Head - Decked 10thou, Port Polish, Std Valves, Double Valve Springs
    - Cams - Undecided - 256/264 or 264/264 or 272/256 (something like that)
    - Block - 40thou Overbore
    - Pistons - TIK 040, Mahle Chrome Rings
    - Conrods - Std
    - Crankshaft - Std (unless it needs work)
    - Oil Pump - New OEM item
    - Sump - Std
    - Intake - Undecided - RWD Manifold With TVIS -OR- ITBS
    - Exhaust - Kaizan Extractors into 2.5" system with Redback Hiflo CAT, Redback Resenator, Redback muffler (not cannon)
    everything else std...
    So what do you think is good/bad what should i change etc..
    feedback please
    Thanks
    Dan
    . h i t o r i k o .
    A
    Parky
    dont bother with quads if your only using a piggy back,
    2 1/4 would be better for the exhaust.
    using it for daily? weekend?
    Dan
    Vic
    Western Subs
    Daily and maybe weekend track days
    . h i t o r i k o .
    Senior Member resol's Avatar
    steve
    vic
    IMO
    build motor with slightly higher comp, stock HG, all new parts and good quality ones (dont just got the standard ACL crap use king or someone a bit better), some nice streetable duration cams and most importantly build it WELL, with good even tolerances all round.
    should be reliable and fun motor, bore the block if you wish i'd prefer higher comp....
    -dan
    gunner:
    ALL DRIFT MODIFICATIONS
    Dan
    Vic
    Western Subs
    its bored out 40 thou
    should i lower the comp? with a HKS head gasket or just std
    and why?
    . h i t o r i k o .
    steve
    vic
    lower the comp? WTF why would you want to do that?
    gunner:
    gay
    n1gger land
    n1gger land
    south korea seoul
    to compensate for the increase in combustion chamber size.
    although higher comp is what u want tho
    Dan
    Vic
    Western Subs
    yeah exactly sunmoon
    but maybe the pistons would be abit iffy
    what about the cams?
    . h i t o r i k o .
    Jonathan
    Well, if you wanted to save some money you could use a standard block and pistons that were OK, rather than doing the overbore. Also, if the crank ballance is going to cost heaps, don't bother.
    It just depends how much $$ you have. I hate to see 20 year olds without a car to drive because they aimed for a better motor they have the knowhow or $ to build.
    Elite rthy's Avatar
    Leo
    Tulla
    try a stock 4age 1st before spending the $
    30kw club
  1. Why should I ? Project (pros/cons)
    By milne in forum General Topics (No Technical Questions)
    Last Post: 19th August 2008, 06:23 PM
  2. carby 4age pros and cons
    By slippry in forum Technical - Questions
    Last Post: 11th November 2007, 09:19 PM
  3. pros and cons of a 16v opposed to a 20v
    By slydar in forum Technical - Questions
    Last Post: 28th April 2006, 03:03 PM
