bump
also got:
Weber & Redline Adapter plate: $200
Got a weber off a ford, runs fine on the 4K, hasnt been jetted down or anything. But makes the 4K breath and go a lot better.
For Sale:
Engine: $250
Engine is a secondhand 4K out of a 1983 KE70 with 150,000kms. Currently it is in my KE25.
Has reconditioned head, new water pump, new front and rear main seals
Engine is very healthy and goes hard
Fresh Castrol gtx oil with genuine Toyota yzze1 filter used and Tectaloy coolant
All you will need is a intake/exhaust manifold gasket and your set (id get a good 1 piece gasket)
Comes with carby on a KE30 intake manifold, but no exhaust manifold unless you buy the extractors as well
Comes with 2 spare rocker covers and a box of spare carby bits n pieces
Comes with starter and alternator
Engine mounts and dizzy extra
Electronic Dizzy: $150
Dizzy is a genuine Toyota 5K item out of a Liteace van
Gearbox: $150
Gearbox came out of the same car, very healthy gearbox, best one ive had, cleaned it up looks great.
Does not crunch at all and shifts smooth, very good gearbox, flushed old oil out and have put new oil in it.
Extractors: $150
Extractors are pacemaker extractors for a KE20 but will fit every K motor corolla
They are in very good used condition
Engine Mounts: $50
Engine mounts are basically brand new KE2# items, seen one month use
Crane Cams Fireball XR700 Ignition: $100 RRP: $150
Brand new never been used
Vehicle Applications:
Toyota Corolla KE1# KE2# KE3# KE5# KE7#
Price & price conditions:
Prices listed above or everything for $750
Contact Details: PM
Delivery & Conditions of Delivery: Pick Up only, will send dizzy and crane cams ignition though
Video of when I first got the engine running in my KE25, tappets hadn't been set yet
After I had fixed everything it ran great, here is a quick video of it driving
ALWAYS LOOKING FOR KE25 COROLLA PARTS
bump
also got:
bump
